Datamine UI7 log errors
I have datamine working in UI7 (439) and its working great.
Only when i go to the datamine debug page my log shows a lot of errors like :
50 11/19/14 20:25:28.798 luup_log:113: dataMine: Events Ret error -1 <0x2ccb0680>
50 11/19/14 20:26:28.798 luup_log:113: dataMine: Events Ret error -1 <0x2ccb0680>
50 11/19/14 20:27:28.809 luup_log:113: dataMine: Events Ret error -1 <0x2ccb0680>
50 11/19/14 20:28:28.806 luup_log:113: dataMine: Events Ret error -1 <0x2ccb0680>
50 11/19/14 20:29:28.808 luup_log:113: dataMine: Events Ret error -1 <0x2ccb0680>
50 11/19/14 20:30:28.802 luup_log:113: dataMine: Events Ret error -1 <0x2ccb0680>
50 11/19/14 20:31:28.850 luup_log:113: dataMine: Events Ret error -1 <0x2ccb0680>
50 11/19/14 20:32:28.844 luup_log:113: dataMine: Events Ret error -1 <0x2ccb0680>
50 11/19/14 20:33:28.799 luup_log:113: dataMine: Events Ret error -1 <0x2ccb0680>
50 11/19/14 20:34:28.885 luup_log:113: dataMine: Events Ret error -1 <0x2ccb0680>
50 11/19/14 20:35:28.803 luup_log:113: dataMine: Events Ret error -1 <0x2ccb0680>
50 11/19/14 20:36:28.815 luup_log:113: dataMine: Events Ret error -1 <0x2ccb0680>
50 11/19/14 20:37:28.808 luup_log:113: dataMine: Events Ret error -1 <0x2ccb0680>
50 11/19/14 20:38:28.824 luup_log:113: dataMine: Events Ret error -1 <0x2ccb0680>
50 11/19/14 20:39:28.810 luup_log:113: dataMine: Events Ret error -1 <0x2ccb0680>
50 11/19/14 20:40:28.806 luup_log:113: dataMine: Events Ret error -1 <0x2ccb0680>
50 11/19/14 20:41:28.798 luup_log:113: dataMine: Events Ret error -1 <0x2ccb0680>
50 11/19/14 20:42:28.834 luup_log:113: dataMine: Events Ret error -1 <0x2ccb0680>
50 11/19/14 20:43:28.805 luup_log:113: dataMine: Events Ret error -1 <0x2ccb0680>
Etc . etc.
And this :
[i]Disk /dev/mtdblock0: 0 MB, 524288 bytes
255 heads, 63 sectors/track, 0 cylinders
Units = cylinders of 16065 * 512 = 8225280 bytes
Disk /dev/mtdblock0 doesn’t contain a valid partition table[/i]
Do i ignore this, or is something wrong?
I get the events ret error. Don’t worry about the mtdblock.
I’m still playing around. If you are getting errors at least it’s initialized. …I get 0 channels which probably relates to that top error.
Tomtcom,
The errors are stille there but datamine is working fine for some time now so i ignore this
Yeah me too, I posted to another thread you are in, I ended up having to uinstall/reinstall datamine and finally got it to work so all is good!
