dataMine app, USB & Insteon/Altsteon
I was wondering if anyone has tried to plug a USB hub into the VeraLite so that you can keep your PLM plugged in and plug in a USB stick that you can use for logging data.
The reason I ask, is I would like to log time, dates and temperatures from my thermostat and it seems like the dataMine plugin would allow me to do this but it needs somewhere to store the data logs.
I see that it was originally developed to log to a USB stick but since I am using the USB port for the 2413U, I don’t have this option. I did see that someone has figured how to log to a NAS but I don’t think that is an option for me.
So, if I can plug a USB hub into the VeraLite and have it recognize the USB stick and the 2413U, then this might be an option. I don’t have a USB hub or I would just plug it in and try it.
Before I go buy one, has anyone else tried this with success? And if so, do you have to make any changes to Altsteon to make it work correctly (like the address of the USB port in the LUA startup file)?
Thanks,
Antonio
If you search the forum for usb hub, you would have seen that their are many who use a hub to attach additional devices.
  • Garrett
garrettwp,
Thanks for the quick feedback. I did try searching but I guess I made my search too specific & searched specifically in the Insteon forum and didn’t find what I was looking for. I will search using just “USB hub” across all of the forums and see what comes up.
Thanks,
Antonio
Use a good usb powered hub. Vera’s usb port power is not that strong due to the Vera power supply.
  • Garrett
