-1-===========================================================================
06 05/23/13 18:57:46.141 Device_Variable::m_szValue_set device: 64 service: urn:cd-jackson-com:serviceId:DataMine1 variable: e[35;1mChannelCnte[0m was: 12 now: 12 #hooks: 0 upnp: 0 v:0xd14390/NONE duplicate:1 <0x2dba1680>
06 05/23/13 18:57:46.142 Device_Variable::m_szValue_set device: 64 service: urn:cd-jackson-com:serviceId:DataMine1 variable: e[35;1mChannelRece[0m was: 12 now: 12 #hooks: 0 upnp: 0 v:(nil)/NONE duplicate:1 <0x2dba1680>
-2-===========================================================================
/dev/sda1: LABEL=“DATAMINE” UUID=“464B-4876”
-3-===========================================================================
rootfs on / type rootfs (rw)
/dev/root on /rom type squashfs (ro,relatime)
proc on /proc type proc (rw,noatime)
sysfs on /sys type sysfs (rw,noatime)
tmpfs on /tmp type tmpfs (rw,nosuid,nodev,noatime)
tmpfs on /dev type tmpfs (rw,noatime,size=512k,mode=755)
devpts on /dev/pts type devpts (rw,noatime,mode=600)
/dev/mtdblock7 on /overlay type jffs2 (rw,noatime)
overlayfs:/overlay on / type overlayfs (rw,noatime,lowerdir=/,upperdir=/overlay)
debugfs on /sys/kernel/debug type debugfs (rw,relatime)
/dev/mtdblock8 on /mios type squashfs (ro,relatime)
none on /proc/bus/usb type usbfs (rw,relatime)
/dev/sda1 on /dataMine type vfat (rw,relatime,fmask=0022,dmask=0022,codepage=cp437,iocharset=iso8859-1,shortname=mixed,errors=remount-ro)
-4-===========================================================================
Disk /dev/mtdblock0: 0 MB, 524288 bytes
255 heads, 63 sectors/track, 0 cylinders
Units = cylinders of 16065 * 512 = 8225280 bytes
Disk /dev/mtdblock0 doesn’t contain a valid partition table
Disk /dev/sda: 2013 MB, 2013265920 bytes
64 heads, 46 sectors/track, 1335 cylinders
Units = cylinders of 2944 * 512 = 1507328 bytes
Device Boot Start End Blocks Id System
/dev/sda1 * 1 1336 1966064 6 FAT16
-5-===========================================================================
SetDataDirectory-/dataMine/
SetMountUUID -464B-4876
SetMountPoint -
SetManualMount -0
-6-===========================================================================
{“Events”:{“count”:791,“last”:1369328245},“dbVersion”:1,“Version”:“0.978”,“LastWrite”:1369328266,“Variables”:[{“Ghost”:false,“Service”:“urn:micasaverde-com:serviceId:EnergyMetering1”,“LastRec”:1369319315,“DrowsyError”:0,“DataType”:5,“Archive”:“1 Lavadora - Watts”,“EnergyCat”:5,“Type”:4,“Logging”:1,“LastVal”:0,“Device”:9,“LastHistory”:1104516000,“DrowsyWarning”:0,“Units”:“watt”,“Id”:1,“DataOffset”:0,“Name”:“Lavadora (watt)”,“FilterEnable”:0,“FirstRec”:0,“Variable”:“Watts”,“historyState”:0},{“Ghost”:false,“Service”:“urn:micasaverde-com:serviceId:EnergyMetering1”,“DrowsyError”:0,“LastRec”:1369304086,“DrowsyWarning”:0,“Type”:4,“Archive”:“2 Lavadora - KWH”,“Logging”:1,“Device”:9,“DataType”:0,“Units”:“kw/h”,“LastHistory”:1104516000,“Id”:2,“DataOffset”:0,“Name”:“Lavadora (kw/h)”,“LastVal”:2.8,“FirstRec”:0,“Variable”:“KWH”,“historyState”:0},{“Ghost”:false,“Service”:“urn:micasaverde-com:serviceId:EnergyMetering1”,“DrowsyError”:0,“LastRec”:1369309186,“DataType”:5,“EnergyCat”:0,“Type”:4,“Archive”:“3 Secadora - Watts”,“Logging”:1,“Device”:17,“Units”:“watt”,“DrowsyWarning”:0,“LastHistory”:1104516000,“Id”:3,“DataOffset”:0,“Name”:“Secadora (watt)”,“LastVal”:0,“FirstRec”:0,“Variable”:“Watts”,“historyState”:0},{“Ghost”:false,“Service”:“urn:micasaverde-com:serviceId:EnergyMetering1”,“DrowsyError”:0,“LastRec”:1369306945,“DrowsyWarning”:0,“Type”:0,“Archive”:“4 Secadora - KWH”,“Logging”:1,“Device”:17,“DataType”:0,“Units”:“kw/h”,“LastHistory”:1104516000,“Id”:4,“DataOffset”:0,“Name”:“Secadora (kw/h)”,“LastVal”:8.1,“FirstRec”:0,“Variable”:“KWH”,“historyState”:0},{“Ghost”:false,“Service”:“urn:micasaverde-com:serviceId:EnergyMetering1”,“DrowsyError”:0,“FilterEnable”:0,“LastRec”:1369334516,“DataType”:5,“EnergyCat”:6,“Type”:0,“Archive”:“14 Router - Watts”,“Logging”:1,“Device”:51,“Units”:“watt”,“DrowsyWarning”:0,“LastHistory”:1104516000,“Id”:14,“DataOffset”:0,“Name”:“Router (w)”,“LastVal”:88,“FirstRec”:0,“Variable”:“Watts”,“historyState”:0},{“Ghost”:false,“Service”:“urn:upnp-org:serviceId:WindSensor1”,“LastRec”:1369332273,“DrowsyError”:0,“LastHistory”:1104516000,“Device”:72,“FilterMaximum”:0,“Logging”:1,“Type”:3,“FilterEnable”:0,“DrowsyWarning”:0,“Id”:15,“FilterMinimum”:0,“Alpha”:1,“DataType”:0,“Units”:“0”,“DataOffset”:0,“Name”:“Viento (dirección)”,“LastVal”:“NNW”,“FirstRec”:0,“Variable”:“Direction”,“historyState”:0,“Lookup”:{“WSW”:8,“ESE”:11,“S”:16,“NNE”:1,“E”:14,“WNW”:5,“NW”:9,“SSW”:15,“NE”:7,“W”:13,“SE”:12,“SSE”:10,“ENE”:4,“SW”:6,“NNW”:3,“N”:2}},{“Ghost”:false,“Service”:“urn:upnp-org:serviceId:RainSensor1”,“LastRec”:0,“DrowsyError”:0,“DataType”:0,“FilterMaximum”:0,“DrowsyWarning”:0,“Type”:0,“Logging”:1,“FilterEnable”:0,“Device”:73,“FilterMinimum”:0,“Units”:“mm”,“LastHistory”:1104516000,“Id”:16,“DataOffset”:0,“Name”:“Lluvia (diaria)”,“LastVal”:0,“FirstRec”:0,“Variable”:“DailyRain”,“historyState”:0},{“Ghost”:false,“Service”:“urn:upnp-org:serviceId:UvSensor1”,“LastRec”:1369328332,“DrowsyError”:0,“DrowsyWarning”:0,“FilterMaximum”:0,“LastHistory”:1104516000,“Type”:0,“FirstRec”:0,“LastVal”:0,“Id”:17,“FilterMinimum”:0,“Device”:74,“Units”:“UVI”,“DataType”:0,“DataOffset”:0,“Name”:“Índice UV”,“FilterEnable”:0,“Logging”:1,“Variable”:“CurrentLevel”,“historyState”:0},{“Ghost”:false,“Service”:“urn:upnp-org:serviceId:WindSensor1”,“LastRec”:1369333533,“DrowsyError”:0,“DrowsyWarning”:0,“FilterMaximum”:0,“LastHistory”:1104516000,“Type”:0,“FirstRec”:0,“LastVal”:9,“Id”:18,“FilterMinimum”:0,“Device”:72,“Units”:“km/h”,“DataType”:0,“DataOffset”:0,“Name”:“Viento (velocidad media)”,“FilterEnable”:0,“Logging”:1,“Variable”:“AvgSpeed”,“historyState”:0},{“Ghost”:false,“Service”:“urn:upnp-org:serviceId:WindSensor1”,“LastRec”:1369333533,“DrowsyError”:0,“DrowsyWarning”:0,“FilterMaximum”:0,“LastHistory”:1104516000,“Type”:0,“FirstRec”:0,“LastVal”:13,“Id”:19,“FilterMinimum”:0,“Device”:72,“Units”:“km/h”,“DataType”:0,“DataOffset”:0,“Name”:“Viento (rachas)”,“FilterEnable”:0,“Logging”:1,“Variable”:“GustSpeed”,“historyState”:0},{“Ghost”:false,“Service”:“urn:upnp-org:serviceId:RainSensor1”,“LastRec”:0,“DrowsyError”:0,“DrowsyWarning”:0,“FilterMaximum”:0,“LastHistory”:1104516000,“Type”:0,“FirstRec”:0,“LastVal”:0,“Id”:20,“FilterMinimum”:0,“Device”:73,“Units”:“mm/h”,“DataType”:0,“DataOffset”:0,“Name”:“Lluvia”,“FilterEnable”:0,“Logging”:1,“Variable”:“CurrentRain”,“historyState”:0},{“Ghost”:false,“Service”:“urn:upnp-org:serviceId:RainSensor1”,“LastRec”:0,“DrowsyError”:0,“DrowsyWarning”:0,“FilterMaximum”:0,“LastHistory”:1104516000,“Type”:0,“FirstRec”:0,“LastVal”:141.2,“Id”:21,“FilterMinimum”:0,“Device”:73,“Units”:“mm”,“DataType”:0,“DataOffset”:0,“Name”:“Lluvia (total)”,“FilterEnable”:0,“Logging”:1,“Variable”:“CurrentTRain”,“historyState”:0}],“Graphs”:[{“Period”:86400,“Channels”:[{“Device”:24,“Service”:“urn:micasaverde-com:serviceId:HumiditySensor1”,“yAxis”:1,“Variable”:“CurrentLevel”},{“Device”:25,“Service”:“urn:upnp-org:serviceId:RainSensor1”,“yAxis”:1,“Variable”:“CurrentRain”},{“Device”:22,“Service”:“urn:upnp-org:serviceId:WindSensor1”,“yAxis”:1,“Variable”:“GustSpeed”},{“Device”:23,“Service”:“urn:upnp-org:serviceId:TemperatureSensor1”,“yAxis”:1,“Variable”:“CurrentTemperature”}],“Events”:1,“Icon”:1,“Name”:“Climatología externa”},{“Night”:1,“Period”:86400,“Channels”:[{“Device”:72,“Service”:“urn:upnp-org:serviceId:WindSensor1”,“yAxis”:1,“Variable”:“GustSpeed”},{“Device”:72,“Service”:“urn:upnp-org:serviceId:WindSensor1”,“yAxis”:1,“Variable”:“AvgSpeed”}],“Name”:“Viento”,“Reference”:“viento”,“Icon”:9,“Events”:0}],“guiConfig”:{“_dc”:“1369320428134”,“graphOptionMarker”:true,“graphOptionWidth”:“5”,“graphOptionShadows”:true},“nextId”:22}
-7-===========================================================================
