I hope to have the next version of dataMine available in the next day or two - it should go to the apps store for approval tonight…
This version has a number of significant changes. The main ones are -:
[ul][li]Notifications: dataMine now downloads the full list of events/notifications from the MCV server. This list is updated every minute, and they can be graphed out as icons along the top of graphs. You can either show all notifications, or just those relevant to the current graph (ie notifications from the devices being graphed, and their parents). The attached picture shows what this looks like. This is obviously a new feature, so I’m open to comments on improving this.[/li]
[li]Installation: There’s now a window that pops up when the dataMine GUI starts if the USB stick is not installed. It prompts you to select the USB drive for use with dataMine, so hopefully eases the installation. This uses the UUID feature of USB sticks to ensure the drive is mounted correctly. I’ll update the manual to provide information on this.[/li]
[li]Speed: There’s a major speed enhancement in the time taken for dataMine to return graph data from Vera, to the browser. This allows Vera to return a lot of data - I’ve had 100,000 data entries returned in less than 10 seconds! But… Unfortunately, doing this poses a health warning to your browser - it may not be able to display the data! I’ll look at better ways to reduce data now that speed is increased.[/li][/ul]
The full list of changes is -:
Version 0.969 18-Feb-2013
[ul][li]Fixed bug with blkid UUID and LABEL return[/li]
[li]Fixed bug with incorrect offset being applied to channels[/li]
[li]Fixed bug with incorrect axis being used[/li]
[li]Fixed potential issue handling string values on startup[/li]
[li]Added debug output /port_3480/data_request?id=lr_dmCtrl&control=debug[/li]
[li]Added “easy install” - GUI selection and configuration of USB drive[/li]
[li]Added graph type 4 for status graphs[/li]
[li]Updated CSS to add missing icons[/li]
[li]Added event notification graphing[/li]
[li]Made graph options persistent[/li]
[li]Major improvement in speed of graph data return[/li][/ul]
Cheers
Chris
