dataMine 0.964 is pending approval by MCV. This issue fixes a number of small issues and adds some small/simple features that people have requested.
[ul][li]Fixed axis names when graphing text values[/li]
[li]Added default wind direction lookup table[/li]
[li]Added whole house graph to energy dashboard (10 minute update)[/li]
[li]Updated version of graphing library (2.3.5)[/li]
[li]Added mechanism to save GUI configuration data on Vera[/li]
[li]Added configuration for min/max values on whole house energy meter[/li]
[li]Limit energy graph value to within min/max limits[/li]
[li]Added support for energy generation[/li]
[li]Allow multiple whole-house energy devices[/li]
[li]Added error message if dataMine fails to load[/li]
[li]Added offset property to varible configuration[/li]
[li]Added configuration for drowsy warning and error times[/li]
[li]Forced full status update if Lua restarts[/li]
[li]Forced full status update if long period between updates (eg if PC was sleeping)[/li]
[li]Modified tooltip on energy usage graph[/li][/ul]
Please refer to the manual for information on setting the defaults - there is no GUI for this as yet!
It should work “straight out of the box” without any additional configuration. Where I’ve added configurable items, there are defaults. These should be perfectly suitable for most people - it’s just people with large power consumption, or PV etc that may want to change things.
I guess this is not really related to dataMine. But for me, when I select Apps->My apps, dataMine shows up as .962, in the list, and I cannot press the checkbox auto update. So do I have to delete the plugin in order to see the newer versions?
Or perhaps I have forgotten about how to install - should I download the files manually? I don’t remember how I did this the last time.
[quote=“vespaman, post:4, topic:173790”]I guess this is not really related to dataMine. But for me, when I select Apps->My apps, dataMine shows up as .962, in the list, and I cannot press the checkbox auto update. So do I have to delete the plugin in order to see the newer versions?
Or perhaps I have forgotten about how to install - should I download the files manually? I don’t remember how I did this the last time.[/quote]
Hi @vespaman,
Excellent now I have 0.964 - the energy stuff is very nice!
However my happiness where shortlived; a few hours after running 0.964, I decided to power off my vera.
Shouldn’t have done that…
All files on the USB partition of which dataMine stored its logs into where erased. I can see remains from them, but a recover with photorec made lots of small useless files, so I’m starting fresh from start again. Had less than 2 months, so it could be worse. However, it brings up the question about backups…
Are there any thoughts on this? I guess it would be nice if there where some way of moving them onto a linux server, but I guess vera does not support nfs mounts(?). Or maybe backup to another USB stick and then sync would be ok.
Edit: Now I have reformatted (into ext4 this time), and dataMine mounts the USB partition fine (verified by logging in with ssh), but when I press the link “dataMine graphing page”, it never shows up. Instead I get “Unable to download channel configuration data from dataMine”. I have cleared the browser cache.
Related might be, that mountType and mountLocation are both empty, but they where empty also before when I had it working.
/mnt/datamine_logs/ are writable and sda2 is newly formatted (clean).
[quote=“vespaman, post:6, topic:173790”]However my happiness where shortlived; a few hours after running 0.964, I decided to power off my vera.
All files on the USB partition of which dataMine stored its logs into where erased. I can see remains from them, but a recover with photorec made lots of small useless files, so I’m starting fresh from start again. Had less than 2 months, so it could be worse. However, it brings up the question about backups…[/quote]
… and, bummer!
I had an issue with my USB stick yesterday when I moved the Vera to include another device - when it started up it shows no files. It seemed the USB stick was mounted OK, but when I SCP’d into the Vera, there were no files. A reboot fixed it, and that’s the only issue I’ve ever seen with the USB.
However, it’s worth pointing out that USB sticks aren’t the most reliable, and they do have lifetime issues, so you raise a good question. I’ve actually been looking at this recently as I want to store more history data, and given that Vera has a nasty habbit of resetting every now and then, I need to periodically store the status…
I personally keep a copy of the files on my PC every week or two. It’s probably not impossible to set something up to do this automagically, but I just plug the USB stick into my PC and copy the files over - just takes a minute.
I just had a quick look on t’interweb, and WinSCP has a scripting mode. I might take a look at how this works, but this would potentially allow this to be (semi) automated (if you get there before me, let me know ;)) http://winscp.net/eng/docs/commandline#scripting.
OK - when you get it working on Linux, I’m still interested I have a linux server…
Hadn’t seen your edit, but it looks like the drive isn’t mounted. mountType and mountLocation shouldn’t be empty. When DM starts, it does a mount check, and if the mountLocation doesn’t equal mountPoint, then the plugin won’t actually start. Without the Lua part of the plugin, the GUI won’t start as it can’t download the configuration (and you get the error you’re getting).
It would be worth looking in the log “cat /var/log/cmh/LuaUPnP.log | grep dataMine” to see what’s logged there.
This is similar to what I saw yesterday - if I types mount, I also saw that it was “correctly” mounted, but there were no files showing. The files were still there though when the stick was plugged into the PC, and when I rebooted Vera it was ok…
I was writing a long explanation of what dataMine does, and I’ve worked out your (my!) problem. It’s the way dataMine looks for the mount after running mount - I’ve foolishly hardcoded dataMine - you’ve got datamine and I think grep is case sensitive (by default at least).
The problem is I run the following -:
mount | grep dataMine > tmpfile, and it won’t find dataMine in your config. I should rethink this! Send me an email and I’ll send you a version that should fix the problem…
OK, so I have now whipped something up, which seams to do about what I need for now.
I think, that if the logs get very big over time, maybe this isn’t the correct method. But at least it can run at times where house is at sleep.
Basically three steps:
Create public ssh keys for unattended login to your Vera from your linux server
Using scp script, copy the whole dataMine log direcory to your linux server.
Put a line in you crontab so it is done once every night.
It would have been nice to use rsync instead of scp, but it seams that it is not included in the vera dist, so scp will have to do. Not sure how much data we will see in the end, but time will tell.
So in detail for anyone that wants to use this type of backup:
Modify the script for your path’s and vera ip (if you don’t have ‘vera’ in your dns/hosts file). Along with your veras IP, you will want to change both destdir and the source path on your vera.
get the files. Vera does not have rsync, so we use regular scp
scp -qpr root@vera:/mnt/datamine_logs $destdir/
create the backup tar ball
tar -cpzf $destdir/datamine_$date.tar.gz $destdir/datamine_logs
fix rights…
chmod 600 $destdir/datamine_$date.tar.gz
remove tempfiles
rm -rf $destdir/datamine_logs
Remove all backups created 2 months ago
rm -f $destdir/datamine_$olddate-*.tar.gz
[/code]
Create the destdir ( in this case ~/backup/datamine )
Once you have tested the above configuration, and you are sure it works just add line to your own crontab (crontab -e in my case) and add a line like this (running 5 o’clock in the morning).
Thanks @vespaman,
I’ll put this onto my Linux box. For info, I’ve been running dataMine for about 16 months, and have nearly 3000 files totalling nearly 50MB. This may ramp up a little in future though as I’ve recently added more power monitoring and some of that is quite fast (potentially every 6 seconds)…
Anyway, this should work fine for a while to come - thanks
[quote=“chixxi, post:15, topic:173790”]Has the version 0.964 or 0.965 been approved yet? I just installed 0.964 by going to apps.mios.com=>plugin details=>versions.
I guess this means you can actually install versions of a plugins which are basically not public, which in my eyes would be quiet bad![/quote]
Looking at apps.mios.com, V0.965 was approved today. V0.964 now doesn’t exist so you shouldn’t have been able to upgrade to that as it’s not listed as a version ???
I got my .964 this way as well. And my auto update doesn’t find 0.965 as usual…
Hopefully, whenever the next vera fw arrives, improvements will be found in this area…
I’m having some problems with dataMine, and I wondered if you might be able to help me find out the cause. At first, it worked fine. Then at a certain point it stopped working. The page itself loads but no chart ever will.
I’m using Chrome and if I turn on the JS console, I see this:
server-side failure with status code 0 app-all.js:4
Error in event handler for 'undefined': INDEX_SIZE_ERR: DOM Exception 1 Error: Index or size was negative, or greater than the allowed value.
at J (chrome-extension://mgijmajocgfcbeboacabfgobmjgjcoja/content_js_min.js:14:142)
at null.<anonymous> (chrome-extension://mgijmajocgfcbeboacabfgobmjgjcoja/content_js_min.js:17:184)
at chrome-extension://mgijmajocgfcbeboacabfgobmjgjcoja/content_js_min.js:1:182
at miscellaneous_bindings:286:9
at chrome.Event.dispatchToListener (event_bindings:387:21)
at chrome.Event.dispatch_ (event_bindings:373:27)
at chrome.Event.dispatch (event_bindings:393:17)
at Object.chromeHidden.Port.dispatchOnMessage (miscellaneous_bindings:253:22) event_bindings:377
GET http://192.168.1.77/port_3480/data_request?_dc=1357819917609&id=lr_dmCtrl&control=status&last=1357819853 500 (Internal Server Error) app-all.js:4
server-side failure with status code 500 app-all.js:4
5
Uncaught Ext.JSON.decode(): You're trying to decode an invalid JSON String: ext.js:21
GET http://192.168.1.77/port_3480/data_request?_dc=1357819922612&id=lr_dmCtrl&control=status&last=1357819853 500 (Internal Server Error) app-all.js:4
GET http://192.168.1.77/port_3480/data_request?_dc=1357819927615&id=lr_dmCtrl&control=status&last=1357819853 500 (Internal Server Error) app-all.js:4
Uncaught Ext.JSON.decode(): You're trying to decode an invalid JSON String: No handler ext.js:21
Any idea what might be causing it to no longer show or update the chart area at all?
