dashboard temperature wrong
It lists the correct city, I’ve got my location set correctly. But the temperature that it displays is never correct. Current temp is 28 degrees F and my dashboard shows 51 degrees F?
Something somewhere else that’s overriding this? Or?
Did you ever figure this out. I have the same issue and it drives me crazy. Thanks
Nope. Still doing it.
Mine is pretty close. But I also have the latitude and longitude entered since I use iPhone locator to change modes.
I’ve got two - in Austin it’s reading about + 10, in Colorado it’s about +35 right now.
at https://home.getvera.com/ it only shows a temp on my Colorado vera and it doesn’t even match the other 2. Doesn’t really matter just annoying.
