Quick question, what/where is the correct tags to use in the static json file to make a button on the dash board appear twice as wide as the standard width.
The “width” tags in the display section only impact the display on the Control Tab, not in the dash board.
Not sure that you can. The spacing/location is part of SceneGroup and ControlGroup. I don’t see any option to change the size of a button on the dashboard though.
Wow, really? No way to size the button on the dashboard panel? So if I want a single button with a fairly descriptive text, it won’t fit and can’t be done. Bizarre.
