Two months ago I bought 6 Danfoss TRVs and a VeraLite. I installed everything (on UI7) but got lots of delays and problems like described by several people on this forum. I didn’t have time to fix it back then, so I put everything aside. Last week I installed five TRVs again after finding this script by dunked.
This script seems to work wel for one of the TRVs (the one I keep for testing), but not for the other five. The only difference is that these five were factory reset and again included (after a firmware upgrade to the latest version, 1.7.481). I could link them, but Vera keeps telling me they are not connected. However, when I manually trigger them by pushing a button, I get an entry in the log:
[code]06 01/05/15 20:13:45.500 Device_Variable::m_szValue_set device: 23 service: urn:micasaverde-com:serviceId:ZWaveDevice1 variable: NodeInfo was: 43,46,72,75,80,81,84,86,8f, now: 43,46,72,75,80,81,84,86,8f, #hooks: 0 upnp: 0 skip: 0 v:(nil)/NONE duplicate:1 <0x2b9f8680>
06 01/05/15 20:13:45.649 Device_Variable::m_szValue_set device: 23 service: urn:micasaverde-com:serviceId:ZWaveDevice1 variable: TemperatureScale was: 2,0,2 now: 2,0,2 #hooks: 0 upnp: 0 skip: 0 v:(nil)/NONE duplicate:1 <0x2b9f8680>
06 01/05/15 20:13:45.650 Device_Variable::m_szValue_set device: 23 service: urn:upnp-org:serviceId:TemperatureSetpoint1 variable: AllSetpoints was: 9,18,18 now: 9,18,18 #hooks: 0 upnp: 0 skip: 0 v:(nil)/NONE duplicate:1 <0x2b9f8680>
06 01/05/15 20:13:45.949 Device_Variable::m_szValue_set device: 23 service: urn:micasaverde-com:serviceId:HaDevice1 variable: BatteryDate was: 1420455021 now: 1420485225 #hooks: 0 upnp: 0 skip: 0 v:(nil)/NONE duplicate:0 <0x2b9f8680>
06 01/05/15 20:13:45.950 Device_Variable::m_szValue_set device: 23 service: urn:micasaverde-com:serviceId:HaDevice1 variable: BatteryLevel was: 55 now: 55 #hooks: 0 upnp: 0 skip: 0 v:0xe7e408/NONE duplicate:1 <0x2b9f8680>
04 01/05/15 20:13:45.951 <0x2b9f8680>
[/code]
When I compare this to the working TRV, I see that they miss the setting of the CurrentSetpoint. The value in AllSetpoints does reflect the setpoint that I manually set on the TRV. The logs for the working TRV:
[code]06 01/05/15 20:13:10.020 Device_Variable::m_szValue_set device: 6 service: urn:micasaverde-com:serviceId:ZWaveDevice1 variable: NodeInfo was: 43,46,72,75,80,81,84,86,8f, now: 43,46,72,75,80,81,84,86,8f, #hooks: 0 upnp: 0 skip: 0 v:(nil)/NONE duplicate:1 <0x2b9f8680>
06 01/05/15 20:13:10.149 Device_Variable::m_szValue_set device: 6 service: urn:micasaverde-com:serviceId:ZWaveDevice1 variable: TemperatureScale was: 2,0,2 now: 2,0,2 #hooks: 0 upnp: 0 skip: 0 v:(nil)/NONE duplicate:1 <0x2b9f8680>
06 01/05/15 20:13:10.150 Device_Variable::m_szValue_set device: 6 service: urn:upnp-org:serviceId:TemperatureSetpoint1 variable: CurrentSetpoint was: 5 now: 5 #hooks: 0 upnp: 0 skip: 0 v:(nil)/NONE duplicate:1 <0x2b9f8680>
06 01/05/15 20:13:10.150 Device_Variable::m_szValue_set device: 6 service: urn:upnp-org:serviceId:TemperatureSetpoint1_Heat variable: CurrentSetpoint was: 5 now: 5 #hooks: 0 upnp: 0 skip: 0 v:0xeac3f0/NONE duplicate:1 <0x2b9f8680>
06 01/05/15 20:13:10.150 Device_Variable::m_szValue_set device: 6 service: urn:upnp-org:serviceId:TemperatureSetpoint1 variable: AllSetpoints was: 5,5,5 now: 5,5,5 #hooks: 0 upnp: 0 skip: 0 v:(nil)/NONE duplicate:1 <0x2b9f8680>
06 01/05/15 20:13:10.390 Device_Variable::m_szValue_set device: 6 service: urn:micasaverde-com:serviceId:HaDevice1 variable: BatteryDate was: 1420484879 now: 1420485190 #hooks: 0 upnp: 0 skip: 0 v:(nil)/NONE duplicate:0 <0x2b9f8680>
06 01/05/15 20:13:10.390 Device_Variable::m_szValue_set device: 6 service: urn:micasaverde-com:serviceId:HaDevice1 variable: BatteryLevel was: 61 now: 61 #hooks: 0 upnp: 0 skip: 0 v:0xe7e408/NONE duplicate:1 <0x2b9f8680>
04 01/05/15 20:13:10.391 <0x2b9f8680>
[/code]
If I go to device>advanced, the CurrentSetpoint is listed for device 23 and its friends.
I have no apps installed except for Info Viewer and I have disabled the script by dunked. Furthermore, I have only three more devices: a fibaro switch, a wall socket, and a Horstmann controller.
Some other things of concern: when changing the Wakeup time on any of the TRVs Vera restarts, and I have regular logs of “UserData::TempLogFileSystemFailure start”.
Does anyone have an idea how I can get the other TRVs to work?
