Danfoss LC 13 Not communicating after batter change
My Danfoss LC 13 batteries run out. Changed them and now I can’t change the setpoint from my Vera unit. The interface says waiting for wake-up to send commands.
Any advice how I can get this working again.
Assuming you see the display light up and can control using the buttons on the LC13 itself, and you used normal batteries, not rechargeable ones. You can wake up the device by pressing the bottom button once. Always works for me. If not you may need to exclude and include.
Cheers Rene
Many thanks. Tried that. No luck.
I did a comma test and I’ve got the bell and antenna icons blinking.
Try to take it off the radiators and then try to include it close to your Vera. Not sure these support network wide inclusion yet.
Cheers Rene
