Im trying to get D-Link DCH-Z510 sirens additional sounds to play with Vera. Additional sounds can be triggered sending NOTIFICATION_REPORT command. Is that same as COMMAND_CLASS_ALARM (0x71)command?
I have tried this: “luup.call_action(‘urn:micasaverde-com:serviceId:ZWaveNetwork1’,‘SendData’,{Node=‘125’,Data=‘0x71 0x06 0x16’},1)” but it is not working.
We recently finished testing the Zipato ZIP-PSE02 siren, which uses the same hardware as the D-Link (and these are all essentially re-badged Philio hardware anyway).
Were you able to get it to appear as an actual siren? I keep getting a switch and a motion sensor device?
Regards,
Grahame
[quote=“martynwendon, post:2, topic:190631”]We recently finished testing the Zipato ZIP-PSE02 siren, which uses the same hardware as the D-Link (and these are all essentially re-badged Philio hardware anyway).
