Custom LED control on scene controller in UI7
Hello All,
In UI5, it was possible to “uncheck” a setting “Let Vera manage the LED” for a scene controller. In this case, you had to use some LUUP code to “turn on/off” the LED for each button from within the scene assigned to the button. In UI7, I don’t see any similar options for the scene controller.
This is important for some scenes, which don’t maintain a state, such as “go to bed.” That scene turns all lights off, etc, but you don’t want the scene “activated” in the morning, because you ran it last night.
My setup is:
  • Vera Edge, running the latest released version
  • Leviton 4 button scene controller
Cheers,
Lincoln
Try setting ManageLeds to 0 under the advanced tab.
