Currency for Vera 2 UI5
All,
At the moment, the currency in the Vera 2 and Vera 3 is set to Euros or Dollars, as I am based in the UK, is there any possibility of bringing in the Pount (£) currency for estimating power consumption.
Also when running the charts for power consumption it is showing in Kwh even though the device is consuming 28watts? Any suggestions?
Regards,
Mike
Mike,
There is the option to choose £ in the present private beta. So it should be in the next public firmware release.
Hi Futzle,
Thanks for the fast response, do you have any ideas on when this beta will be going to the next release?
Many thanks,
Mike
There has not been a mentioned date. MCVFlorin mentioned a week or so. But giving a date is like playing Russian r0ulette when it comes to development.
  • Garrett
Well the new Firmware is out and yet no changes to the currency, anyone from MicasaVerde wish to comment?
The last firmware was to address bugs and not adding any new features to the build.
  • Garrett
Oh well, lets hope the next release brings some new functionality!
Where do you expect to be able to select £ ? (On the [tt]Setup[/tt] > [tt]Location[/tt] tab there’s the option for Dollars / Euros / Yen / Pounds).
As oTi@ mentioned, the drop down does contain the additional currencies. Did not realize that they added the additional ones.
  • Garrett
Ah Just seen it, just had to power cycle the unit.
Thanks for that guys.
