I’m not sure that the CT30E - 2Gig Programmable ZWave Thermostat could provide the temperature in Celsius, could it ?
From the Operations Manual:
“Set oF-oC display
Touch the oF and it will toggle to oC.”
http://store.homeseer.com/store/2GIG-ZSTAT-CT30E---Z-Wave-Thermostat-2GIG-P971C67.aspx (click on Operations Guide to download)
I went in this manual, and made a search on “celsius”… :![]()
That word is not there…
No Problem, searching the entire document for the letter C is no fun either.
Does anyone know how to switch to farenheitnon the on the Vera .i don’t see anywhere in the advanced option page that has a c I can switch to f. Please help. Thanks
Goto Settings > Location.
Sorry to be a total newbie but I don’t see location in the settings. The model I have is a ci300e 2gig
I was referring to setting up the Vera location.
From your Vera goto the Setting tab > Location Tab. It should look like the attached. Also notice how the city appears twice. One for timezone and one for location.
Ok perfect thank you very much for the help.
I had the same problem. I changed the setting in Setup/Location to Celsius and then back to Fahrenheit and it seemed to fix the issue. I am now able to view thermo data in F instead of C.
