Just got a CT101 from Lowes. I am on UI7 and am new to vera, i have a vera 3. I can put it in heat or cool mode and change the temperature and it works fine. If i put it in auto mode it just keeps the last set temp from the last heat/cool mode on the actual thermostat. The vera interface displays something completely different and when i change it up or down it doesnt change on the actual tstat.
