Critique of my first PLEG setup required
As per Richard’s suggestion to my post [url=http://forum.micasaverde.com/index.php/topic,23314.0.html]http://forum.micasaverde.com/index.php/topic,23314.0.html[/url] to stick my PLEG logic on this board to get some feedback. So here goes.
I’ve cut and paste the logic below together with a summary of what I’m trying to acheive. I would be grateful of any feedback anyone could provide of how I could improve my logic, where I’ve made mistakes, how I could simplify it, how to solve my hotwater issue (see below) etc.
Hardware
My system consists of a Vera Lite, Secure Wall Thermostat and Secure Boiler Receiver (2 channel). I’ve also installed a number of Virtual Switches (VS) to allow manual overrides etc.
Brief
[ul][li]Heating and hot water turn on/off according to daily schedules[/li]
[li]Home/Away button so can override schedules for holidays, weekends away[/li]
[li]Frost protection - if temp in house (measured by thermostat) ever got to 5degC heating would come on irrespective of any schedule, VS positions etc.[/li]
[li]Manual override of central heating/hotwater to leave on in between schedules, say, weekend daytime if not out[/li][/ul]
Problems
[ul][li]Manual hotwater- whilst it turns the hotwater ‘heat’ on, this seems to turn off before the actual hot water cylinder thermostat (not connected to Vera) has been satisfied. I want it to stay on until I VS turns off.[/li][/ul]
Future Plans
[ul][li]Set a minimum house temp based on outside ambient temp e.g. if outside temp drops below 10degC turn on heating to maintain house at 15degC irrespective of schedule (to see if keeping house at set temp saves energy compared to letting cool down too much[/li]
[li][/li][/ul]
Logic output report:
Triggers
Name Description
Home VSHomeAway is turned on (Virtual Switch)
HotWaterOn _HotWater is set to heat
HeatingOn _Heating is set to heat
HeatingOverride VSManualHeating is turned on (Virtual Switch)
HotWaterOverride VSManualHW is turned on (Virtual Switch)
Schedules
Name Type Time Days Random On Delay Off After Type Off Time Off Days Random Off Delay
WeekdayAM Weekly 06:30:00 1,2,3,4,5 None Weekly 08:00:00 1,2,3,4,5 None
WeekdayPM Weekly 16:45:00 1,2,3,4,5 None Weekly 22:00:00 1,2,3,4,5 None
WeekendAM Weekly 07:30:00 6,7 None Weekly 09:30:00 6,7 None
WeekendPM Weekly 17:00:00 6,7 None Weekly 22:00:00 6,7 None
WeekdayAMHW Weekly 06:30:00 1,2,3,4,5 None Weekly 07:30:00 1,2,3,4,5 None
WeekdayPMHW Weekly 17:00:00 1,2,3,4,5 None Weekly 18:00:00 1,2,3,4,5 None
WeekendAMHW Weekly 07:30:00 6,7 None Weekly 08:30:00 6,7 None
WeekendPMHW Weekly 17:00:00 6,7 None Weekly 18:00:00 6,7 None
Device Properties
Name Device Name Device Variable
HouseTemp Thermostat CurrentTemperature
SPCurrent Thermostat CurrentSetpoint
SPTarget Thermostat SetpointTarget
Conditions
Name Expression
Away Not Home
AtHome Home
AutoOnHW Home and !HotWaterOverride and (WeekdayAMHW or WeekdayPMHW or WeekendAMHW or WeekendPMHW)
AutoOffHW Home and !HotWaterOverride and (Not(WeekdayAMHW or WeekdayPMHW or WeekendAMHW or WeekendPMHW))
AutoOnHeating Home and !HeatingOverride and (WeekdayAM or WeekdayPM or WeekendAM or WeekendPM)
AutoOffHeating Home and !HeatingOverride and (Not (WeekdayAM or WeekdayPM or WeekendAM or WeekendPM))
MorningSP AutoOnHeating and (WeekdayAM or WeekendAM)
EveningSP AutoOnHeating and (WeekdayPM or WeekendPM)
NonHeatingSP AutoOffHeating and (Not (WeekdayAM or WeekdayPM or WeekendAM or WeekendPM))
SPAnalysis SPCurrent==SPTarget
TempAnalysis HouseTemp==SPCurrent
ManualHeating Home and HeatingOverride
ManualHotWater Home and HotWaterOverride
Actions
Actions for Condition: Away
Immediate
Device Action Arguments
_HotWater SetModeTarget NewModeTarget=Off
_Heating SetModeTarget NewModeTarget=Off
VSManualHeating SetTarget newTargetValue=0
VSManualHW SetTarget newTargetValue=0
Receiver SetModeTarget NewModeTarget=Off
Thermostat SetCurrentSetpoint NewCurrentSetpoint=5
Actions for Condition: AutoOnHW
Immediate
_HotWater SetModeTarget NewModeTarget=HeatOn
Actions for Condition: AutoOffHW
Immediate
Actions for Condition: AutoOffHeating
Immediate
Actions for Condition: MorningSP
Immediate
Thermostat SetCurrentSetpoint NewCurrentSetpoint=18
Actions for Condition: EveningSP
Immediate
Thermostat SetCurrentSetpoint NewCurrentSetpoint=21
Actions for Condition: NonHeatingSP
Immediate
Actions for Condition: ManualHeating
Immediate
Actions for Condition: ManualHotWater
Immediate
Your problem with the hot water relay is that it has a built-in safety function. If it does not receive a Z-Wave command at least once per hour, it turns off. The fix is not difficult. Add the following to your PLEG:
Schedules
I30M On: Interval 30 minutes
Device Properties
HWRMode Hot Water Relay ModeTarget
Conditions
_HWPulse I30M
Actions
_HWPulse Hot Water Relay SetModeTarget NewmodeTarget={(HWRMode)}
This will resend the last ModeTarget to the relay every thirty minutes to keep it in that state.
You could perhaps simplify your logic to change the temperature setpoint. This will be even more beneficial if you add TRVs. This is not a direct replacement for your current logic - just an example:
Conditions
_SetPoint AutoOnHeating ? ((WeekdayAM or WeekendAM) ? 18 : 21) : 5
Actions
_SetPoint Thermostat SetCurrentSetpoint NewCurrentSetpoint={(_SetPoint)}
The condition _SetPoint selects the required setpoint according to the state of AutoOnHeating and the schedules. If AutoOnHeating is false, the value will be 5. If it’s true, the value will be 18 if either WeekdayAM or WeekendAM are true or 21 otherwise. Whenever the value of _SetPoint changes, the action sends the new value to the thermostat.
I use this type of control for my heating. The expression that calculates the required setpoint includes many different terms that adjust for home/away, time schedules, vacation, heating on/off, etc. I don’t actually ever turn the heating off - just set the appropriate setpoint. That way frost-detection is automatic. However complex the expression, it is still just one Condition and one Action.
