Creating scenes to add to scenes to get the task done.
I am a new user to Vera. I have a lamp plugged into a Wemo unit that is access through Vera and a switch for the overhead lights. I am trying to create a scene that will turn out the lamp when the overhead is turned on, turn the lamp back on when the over head light is shut off, and the ability to turn them both out at night.
This seems very difficult to me. Step by step, if this is possible, is the only way for me at this point. Please help.
Thank you.
Not too tough to solve with PLEG and the Day/Night apps
Inputs: WeMoOn, IsNight
Condition: WeMoOn AND NOT IsNight
Action: Turn Lamp Off
Condition: Not WeMoOn AND NOT IsNight
Action: Turn Lamp On
If you need help with PLEG, there are tons of threads on the subject along with a PLEG basics primer
@henryiii, you will find step-by-step instructions for creating scenes here.
Thank you for the replys. However, some or most of the terms used are foreign to me. As helpful to some as the replies may be, they are over my head.
Select Automation tab
Select ‘new scene’ under automation, name the scene
Select ‘trigger’
Select ‘add trigger’
Drop down please select device
Select your device, the overhead light
Select ‘a device is turned on or off’ in the next drop down
Name the trigger something like ‘overheadlighton’
Select ‘device is turned on’ in the next drop down
Select ‘back to triggers’
Select ‘devices’
Choose Off on the wemo controlled light
Click ‘confirm changes’
This scene will turn off the wemo light when the overhead is turned on.
Do the same thing for the ‘off’ trigger with a second new scene.
This will be your first home automation. Do this and we can tell you how to add the part that cancels the scene when the lights are switched during the night.
That is it gentlemen. You guys ROCKED IT!. Mission accomplished with all your help. Thank you very much.
GO SEAHAWKS!
