Below is a link and the thread will describe what and how. You could also try the embedded MCV process via Device > Add Device > Add an IR device. That should at least do some of you items.
The Epson that is under the Devices in Mios doesn’t work for my Projector and the Pivos one gives an error (I attached a screenshot). The rest seem to have worked.
First rule of thumb: Don’t Panic.
Declaration:
I do not use Vera to control my IR devices but another program called iRule.
Continue…
Stick with one device first and stay within the GC toolset whilst doing the initial testing. Yes, the GC program enable after capture to test the code sending.
Some device need the ir code sent multiple times. When you do a test send play with this but try it on a number (eg. 2, 99) and another series of commands. This should determine what is required to be sent in Vera.
The easiest way to implement multiple send in Vera for now is copy and paste code set end to end. Eg 1234 5678 twice 1234 5678 1234 5678 type of thing.
Been using iRule, love that app! Everything so far works well, and I love how I can make my own custom remotes…Here is a quick one I made for the Pivos Aios
