Creating a scene triggered by thermostat state or setpoint
I wonder if it is possible to create a scene triggered by a thermostat changing state from on to off. Or use the setpoint temperature as a value compared to ambient.
I need to control some rfxcom switches to turn on heaters with a scene so I can not use association.
Sent fra min Nexus 6 via Tapatalk
Easy to do with PLEG …
You can use Device Property Inputs in PLEG to drive your Automation logic where the device does not provide a trigger that can be used in a Scene.
[quote=“RichardTSchaefer”]Easy to do with PLEG …
You can use Device Property Inputs in PLEG to drive your Automation logic where the device does not provide a trigger that can be used in a Scene.[/quote]
Thanks. Just installed PLEG.
