creating a scene involving an armed sensor
I’m embarrassed to say how many hours I spent trying to figure this one out. In an attempt to help others who may have the same problem, I submit this. I have two types of sensors – motion detector and magnetic door/window sensor. I wanted certain lights to be turned on when the motion detector was armed and detected motion or the gate was open. Of course, I use a separate same for each detector or sensor. What threw me was the field “tripped?” I finally discovered that in this field, I had to select “yes”. I didn’t find anywhere in the wiki that I had to do this.
Also, I created two scenes in global scenes to arm the sensors and to bypass the sensors.
Thanks Les,
I’ve modified http://wiki.micasaverde.com/index.php/Intro_Security and added your explanation.
