When I install a plugin from the app store thing, it creates a device where I can change the settings. I modified the RadioRA plugin to support LiteTouch, and I’ve uploaded the 4 files and restarted LUUP. But the device isn’t automatically created. Do I have to manually create the device in the develop apps tab?
The answer to this question depends on what changes you made!
If the file names are the same … and you did not change the D_XXX.xml file and did not change the device type … you will only be changing the implementation of the previous created device (when you downloaded from the App store).
[quote=“RichardTSchaefer, post:2, topic:177783”]The answer to this question depends on what changes you made!
If the file names are the same … and you did not change the D_XXX.xml file and did not change the device type … you will only be changing the implementation of the previous created device (when you downloaded from the App store).[/quote]
I changed the filenames, and I changed everything in the files. There are NO references to RadioRA in there at all anymore. The only thing I didn’t change was the GUID, since I read somewhere that a new one would be generated automatically when loading the files.
Also to note, I uninstalled the RadioRA plugin after I downloaded the 4 files. The new files I’m uploading are:
-rw-r–r–@ 1 xxx staff 3172 Nov 12 11:03 D_LiteTouch-RS232.json
-rw-r–r–@ 1 xxx staff 1160 Nov 12 11:01 D_LiteTouch-RS232.xml
-rw-r–r–@ 1 xxx staff 6677 Nov 12 17:02 I_LiteTouch-RS232.xml
-rw-r–r–@ 1 xxx staff 521 Nov 11 18:26 S_LiteTouch-RS232.xml
Am I missing a file?
Should I be creating this as a plugin on apps.mios.com and making it private until it’s all working?
I think you need to create your new device. Try this:
Go to APPS, Develop Apps and click on Create device
Enter only the following:
Description:
Upnp Device Filename: D_LiteTouch-RS232.xml
Upnp Implementation Filename: I_LiteTouch-RS232.xml
Click the Create device button, click SAVE/Reload and then reload/refresh the browser page. You should now have your device.
Looks like I got it working. I had to enter the urn: line also.
