I have a Vera Lite and have a Honeywell YTH8320ZW1007/U Z-Wave Enabled Programmable Thermostat.
I am a NewB when it comes to advanced programming of the Vera. I am able to do pretty simple scenes and such.
I was wondering if there is any way to set a maximum setpoint on the thermostat so that if someone selects a higher temp on the thermostat keypad it will set it to the maximum setpoint?
i.e. If the max setpoint is 72° and someone (namely my son) puts the temp to 75° via the thermostat keypad, it will reset the thermostat to 72°?
Thanks for any help that you can provide!
