Create Latching Circuit
My external lights are controlled from multiple access points activating a pulse relay. Hence, in order to integrate a zwave scene, I subsequently had to configure a Fibaro switch as pulse output to activate the relay. I wish to monitor the ON/OFF state and duration of lights ON for which I require a “1” following a pulse command. Anyone having a suggestion how to accomplish this?
How about simply replacing the pulse relay stuff with the Fibaro?
