cp.mios.com and iVera not working? (remote access)
Is anyone else having trouble with remote dashboard access via MyMios (cp.mios.com) or iVera?
I can log in, but it hangs every time when loading up the dashboard in MyMios or in iVera on iPhone. This has been going on for a few days.
-sk
http://forum.micasaverde.com/index.php?action=search2&search=remote+access
I noticed mine stopped being able to access remotely yesterday. It could have occured though some days before.
When I go to the dashboard on cp.mios.com it complains about not getting any data and does not display my scenes or devices. Homebuddy doesnt now work remotely either.
Broken for me too. Everything was working up to today, but neither cp.mios.com nor iVera works now!
Just another fine day in Vera land…
–smb
Same problem here…
Local access worked fine for me this morning but Mios just hangs.
Remote access via cp.mios quit working about a week ago for one Vera. No problems (yet) with other two Veras!
I think its time to bypass cp.mios.com and just access my vera directly.
I’m not able to connect to the Dashboard of my vera2 via cp.mios.com. IIRC, I was able to do so last week. Not sure if my upgraded FW is at fault (didn’t set up a tunnel when starting up?) or if it’s cp.mios.com that’s at fault.
I get the “Unable to execute command” when trying to access via smart phone.
Please see the following post:
http://forum.micasaverde.com/index.php?topic=5255.msg29692#msg29692
An increasing number of people have been having problems accessing vera remotely.
I guess I am lucky, I can access remotely via cp.mios.com, but it was a slow load I thought it wasn’t going to come up, waited some more, and then success. I am using IE8.
I was finally able to access my Vera2 through the Dashboard after SSH’ing into the Vera and rebooting. Have not had a problem since I did that.
While this may work for some period of time, it will get to a state where you will not be able to log in again without another reboot. I think there is something fundamentally broken with the way cp.mios.com and Vera establish and maintain communication. It could be the server gets overloaded and dumps connections, but who knows since we have zero communication from the folks who make and maintain this stuff. All I know is that it is happening to more and more people and it can’t just be that their Vera’s are faulty.
Its being worked on at the moment and I believe it was down to a server side issue that may require a software update to fix; which I guess is something to do with increased load etc…
