Countdown Timer in UI7
I am trying to create scenes with the countdown timer and when I try to configure an action on the timer, it auto selects either muted or unmuted. I am just trying to select Start, Cancel, Restart, or Force. When I select one of those it also forces me to either have muted or unmuted selected too.
Is this something that can be fixed for UI7?
I can’t fix this. MCV has removed the concept of a UI element group in the UI7 scene editor and hasn’t supplied a replacement. The same thing happens if you try to make a scene which modifies only one of the aspects of a thermostat (say, the setpoint without adjusting the mode).
As a workaround, once you’ve created the scene, go back and edit it in the advanced scene editor and remove the action that you don’t want to happen.
