Cooper switch display lights
I have three Cooper Auxiliary switches RF 9542 associated with a master switch RF 95640. The lights on the switch of one of the Auxiliary switches this morning was yellow instead of blue. Any ideas what might be happening? It does not control the master this morning also. I have excluded it and included it back in. Light switch is still yellow and does not control the master . The other two switches still are fine
After including it, did you recreate an association? You’ve got to tell the auxiliary which master to activate.
Yes I did recreate to association. The switch had worked great for 6 months. I may have to reset circuit breaker to the switch and see if that changes anything.
Turning off circuit breaker and turning it back on made the status lights on the switch switch from yellow to blue and the auxiliary switch does not control the master
Begin again. Exclude, include, associate.
If it still doesn’t work, then I would assume a bad switch.
