Cooper Aspire 5-Scene Controller RFWC5 (Problem Adding)
I am having an issue adding an Aspire RFWC5 controller to my Vera3. I follow the device inclusion process, the device gets added, all appears normal except the “Scenes” tab has no way to modify scenes. Not sure what to do next. I have followed the instructions to remove, and then re-add again but same issue. Any one have any ideas? I am including a screen shot of the “Scenes” tab for illustration. Any advice would be appreciated.
You have to create a scene, and add the button (1-5) as a trigger.
On a side note, when you do try to get yours working, see if hitting the button turns the light on and off. I opened a support ticket because direct association does not work for my version of the switch.
more info:
http://wiki.micasaverde.com/index.php/Cooper_Scene_Controller
http://www.cooperindustries.com/content/dam/public/wiringdevices/products/documents/technical_specifications/advancedtechinfo_V2.pdf
http://forum.micasaverde.com/index.php?topic=15725.0
How do we ‘add the button (1-5) as a trigger’? I cannot find any place to select those buttons.
I was trying to follow the wiki page you listed, but it looks like it is quite outdated (doesn’t match the latest UI), and I am rather a noob with vera lite.
Could you expand on how you made it to work?
You create a new scene, in that scene you add the scene controller as a trigger. There you select “A scene is activated” or “A scene is deactivated” a text box should show up and you enter the button number e.g. 1.
  • Garrett
Thank you garrettwp.
My first problem was using “#2_Scene Controller,” as I missed the name I gave to Aspire, and thought that scene controllers are listed first. Once I made that mistake, I was following with more errors. Thanks to your explanation, I removed all previously created scenes, started from scratch, and everything it is working now. Big thanks.
One way to potentially see that the new scenes are added to RFWC5 is to check that device, as it will show those scenes in both “Control” and “Advanced / Scenes” tabs.
Another interesting thing is that when you select “A scene is activated,” then Aspire will deactivate that scene on the second button press.
Although, I cannot figure out how to make a scene controlled device to talk back to scene controller to let it know to change LED state to follow that device state.
Jacek
