I’m replacing existing 3-way switches with Cooper Z-wave RF9536 (master) and RF9542 (accessory). The master is connected to the hot/line side and accessory to the light/load side of the circuit. I have positively identified each of the two traveler wires and have them connected per the wiring schematic in the instructions.
Result: Master switch controls the light. Accessory switch will show the dim level etc as it is changed by the master but it will not operate the light.
The installation instructions under diagram 2.3 and 2.4 indicate that the blue wire from the master should be connected to the traveler that connects the accessory switch with the light. However, if you look at the schematic below the diagrams it shows the master red, not blue, wire connected to the accessory wire going to the light.
I’m new to the Z-Wave products so I must be missing something. Any help would be appreciated.
It may have helped if you linked to the Cooper Aspire RF9536 manual that you were referring to and the diagram that is attached below.
The diagram shows that the red from the master is joined to the blue from the accessory AND the black to the light. All three wires in a single wire nut. Then the blue from the master goes to the other blue on the accessory.
Thanks for your response and sorry for not linking to the diagram. That is the way I currently have the switches wired but for some reason I can’t get the accessory switch to control the light. I’ve even replaced the switch on the rare chance it was defective.
Have you included the master switch into the Z-Wave network yet? Are the blue LEDs blinking? If they are, the master must be included into the Z-Wave network for both switches to function correctly.
Thanks for your help…I really appreciate it. I did include the master…I even excluded it when installing a new switch and included it again thinking that was the problem.
Are you using an incandescent bulb? If you are using LED bulbs, test with an incandescent. If the switch is wired correctly and included, with no flashing blue LEDs, then it should be working. If it still doesn’t work, you’ll need to contact the manufacturer.
Yes, a total of 150 watts incandescent. I tried contacting Cooper Aspire but they have not responded to my call or emails. I’ve spent hours searching posts to figure this out but I haven’t seen anything specific to this problem. It is so odd that the blue LED’s on the accessory switch will show the dim and on off status but will not operate the light. I’m not one to give up easily but it’s probably time for me to move on to another brand. Thanks again for your help.
