Converting Worldweather app variable windspeed to single sensor
Dear All
With the worldweather app you get single sensors like outside temperatuur, humidity etc.
However, i also want to display and log WIndspeed (m.s) but I do not see windspeed as a seperate sensor.
In this way I also do not see windspeed seperately in Authomation or imperihome.
in datamine I can log and trend the windspeed variable and I can see it as seperate variable, see attached picture.
does anybody know how I can convert this windspeed variable such that it can be displayed as a separate sensor in Vera?
See this thread:
http://forum.micasaverde.com/index.php/topic,11815.0.html
  • Garrett
Garrett
Thanks for pointing me to this.I can see it is a very actual topic. From the topic I can see that this is Work in Progress and there is no solution yet
Lua programming is not my strongest points but i will try to assist if possible.
