Controlling Light with Motion Detector
I just hooked up a Aeotec Multisensor. I want it to control a light outside so it goes on with motion only at night and then go off automatically after five minutes. Is the best way to do this with a scene and trigger or should I be looking to associate it with the light. I read something about association but not sure what that is.
Also, I have been using GE/Jasco on off switches. Should I look at a Leviton or Cooper with Instant on for this one light?
thanks,
Mike
Search the forum… multiple solutions. Or PLEG (without license :-))
[quote=“rinconmike, post:1, topic:179899”]I just hooked up a Aeotec Multisensor. I want it to control a light outside so it goes on with motion only at night and then go off automatically after five minutes. Is the best way to do this with a scene and trigger or should I be looking to associate it with the light. I read something about association but not sure what that is.
thanks,
Mike[/quote]
Mike,
No, don’t change switches.
If you haven’t already, install the Day/Night plugin.
Create a scene that is triggered from your motion sensor.
Refer to attached if you don’t know how to do that.
Enter a Name for your scene
Then go to Devices and select the lights you want to turn on
Then add a Delay on the Devices for 5minutes and turn off the lights that you turned on
Then add this code to your Luup panel:
if ( luup.is_night() ) then
return true
else
return false
Then, below the panel, select Save Lua
Then Save the scene
This scene will be triggered from the sensor you select and turn on a light for 5minutes.
@Bulldoglowell - This is a good plan, but the Day/Night plugin would not be used/required in your scene. You scene can be implemented on a stock Vera with zero plugins.
ZWaver is right… I just get a nickel royalty for every install!!
Actually, I thought it would be helpful for Mike to see on his UI what state Day/Night is in. Plus I figured that once he did this, he may want to do more with Day/Night.
I’m on UI5 still, so I am unsure if the new UI gives you that dashboard visibility.
Thanks guys. First time I am using a motion sensor with the Vera3 (UI5). With the multisensor, it is currently set to go back to arm mode after 5 minutes of last motion. So I would like the light to stay on while triggered (in the disarm state). So if I am walking around by the motion sensor, the light will go on. If I am working there for 20 min, it will stay on and then eventually go off 5 minutes after the last motion is detected.
So would I implement two scenes where the second one is to turn it off instead of a delay, or is that not needed and and the single scene will continually be triggered while there is motion and then the delay will happen after last motion?
Also, what is considered night? Sunset?
Is there any use of the light sensor in the multisensor?
One more question, if someone manually turns the light on, does that change anything? Or will the scenes still run on the triggers of the motion and no motion.
thanks again.
Mike
[quote=“rinconmike, post:6, topic:179899”]Thanks guys. First time I am using a motion sensor with the Vera3 (UI5). With the multisensor, it is currently set to go back to arm mode after 5 minutes of last motion. So I would like the light to stay on while triggered (in the disarm state). So if I am walking around by the motion sensor, the light will go on. If I am working there for 20 min, it will stay on and then eventually go off 5 minutes after the last motion is detected.
So would I implement two scenes where the second one is to turn it off instead of a delay, or is that not needed and and the single scene will continually be triggered while there is motion and then the delay will happen after last motion?[/quote]
You got it. Just one scene for on, and the other one when the motion sensor does not report tripped. In that case, as long as you are loitering around in the range of the sensor, and moving a bit, you are good. You may like to set the On Time of the sensor to be longer not shorter in this use. say 6minutes, not 1 minute. (that setting is a sensor configuration and it is the length of time the sensor stays tripped each time it detects motion)
Yes, later you can use that Day/Night tool to adjust that to say 30mins after sunset and 30mins before sunrise. There are ways to use that in Luup.
Some folks use the sensor to turn on lights if the room is a low light location (no windows) and the day/night tool isn’t effective. That’s one example.
scenes will run regardless of the status of any of the switches you are controlling.
