hello !
In first place I inform what I have searched on the forum and not found nothing to solve this, at least not clearly. ;D
I must buy a projector screen and the model choosed has only RF remote control…what product can learn this command and integrate with vera3 to send this signal like Sqblaster does.
I will love found a screen with infrared remote,I have sqblaster then do not have problem to automate that…
thanks in advance.
Report what you find … I would be interested as well.
I’m sure there are other solutions than ones with RF remotes only.
One option is to buy one with a standard tube motor, and then wire this to something like the following:
http://www.asihome.com/ASIshop/product_info.php?products_id=3474
Alternately you could hack the rf remote with one of the Vera supported relays to control it.
I believe there are some threads detailing this or very similar things.
