I have a GC100-06 andf I just installed the GlobalCache plugin for my VeraLite. It seems that there is no documentation at all for this plugin. does anyone have a general guide for how to configure and use the plugin?
Get the documentation for the GC100 and define it’s IP address as a static IP.
You will need to know how to do this with your router. Probably need to get your router
documentation.
After you get a static IP address for the GC100 … then use it in the Advanced tab for the plugin device. Set the IP address in the Settings page.
Also email me and I will send you a patch to the GC100 driver … so the relays show the proper status.
thanks for the reply - I have done that already… the IP is set static on the GC100. I went into the device settings for the GC 100 in the advanced tab and set the IP and MAC address. what are all the other settings for? do I need to mess with any of them?
so keeping in mind that I am BRAND new to veralite (I came from the homeseer world), how do i actually make the gc100 do something?
for instance, I have the control app on my iphone. I would like to be able to go into that and tap a button to trigger an event which would turn on my home theater using the GC100.
If the GC100 connected properly … then it should create Switches that represent the relays on the User Interface.
Do you get any errors at the top of the Vera Console indicating problems ?
For IR control you need to go into add devices and then add IR device and follow the steps to add your IR devices. you will then be able to control that device from the advanced tab like turning the tv and components on and off.
i tried going in and adding the ir devices (although the available ir ports are 8,9 and 10 - not 1,2 and 3) i chose my device (pioneer elite 1130hd tv) and it said it found 5 sets of ir codes but when i went through them and tried power on for each, none of them seemed to work.
i also noticed that when sending the “on” command from each of the 5 sets, the ir port light did not light up on the gc100.
so im not sure if the gc100 is even sending any ir how can i troubleshoot?
[quote=“RichardTSchaefer, post:4, topic:176867”]If the GC100 connected properly … then it should create Switches that represent the relays on the User Interface.
Do you get any errors at the top of the Vera Console indicating problems ?[/quote]
im not seeing that. and i dont see any indication of errors.
and i spoke too soon in my previous post i was able to configure my fios dvr . but i cant get the pioneer tv or apple tv to work
Can you give some more detail? How would i do this?
GC100/06 Quickstart Guide.
Some old discusions about adding IR Devices. Note not all up to date.
http://forum.micasaverde.com/index.php/topic,9357.msg97355.html#msg97355
Hey thanks for the info. I had the getting started guide that came with my GC100 but the link to the forum post gave me a lot of insights. I am now further ahead than i was but I still have some questions.
So I was able to set up a device for my fios DVR (motorolla). WHen I go to Devices, AV Gear i see my Fios DVR device and if i click on the COntrol icon next to it, i get a screen that looks like a remote control layout and when i click the buttons it seems to be sending the IR through the blaster out to my device. This is very cool.
With that said, I am confused about how to include this in any scenes. so for instance, lets say that when i turn on the light in the living room, it would trigger an event which would turn on my DVR via the GC100 (not the most practical example but I am trying to keep this simple until i get it all figured out).
If I go into the Automation tab, and click on New Scene, It shows all my devices, including the GC100 Device and the FiosDVR device. But it doesn’t seem to let me do anything with them. How could I set the new scene to send specific IR commands, such as “turn on the DVR”? I’m sure I am missing something simple here.
Now my other question is that I have not been able to get a device set up for my Pioneer TV because it doesn’t seem to respond to the commands from any of the 5 code sets found during the setup process. So if the correct codes are not in the database, I assume that I have to set up the device with any IR code set and then go in and edit that chosen code set and add the custom IR codes that do work. But how do I go about editing the ir codes on the device?
I appreciate all your help and I feel like I am very close here. Once I get these details worked out I think this is going to be a really great solution!
Easy on first. In the Scene, goto the Advanced Tab and then pick your IR device and click add. This will then build and load the command available.
Second one easiest way is still create a device as you have with the others.
In the Advance for the device it will include the impl file (XML) file that is created/used for the ir set. Download this locally.
Using you Ihelp learn the new it codes.
Modify the XML file using an XML editor and replace the codes with the new ones. Save and then upload back to your Vera.
But on a desperate note. Have you checked the App Store, there are a few already there and believe the two you have mentioned may have been created. Worth verifying as well.
awesome - sounds easy - i’ll give it a shot!
[quote=“Brientim, post:11, topic:176867”]In the Advance for the device it will include the impl file (XML) file that is created/used for the ir set. Download this locally.
Modify the XML file using an XML editor and replace the codes with the new ones. Save and then upload back to your Vera.[/quote]
I’m not sure what ihelp is… is that the new version of the learner software from GC? I believe I have a GC-IRE and a GC-IRL - but its been a long time since I messed with that. what is the process here for learning codes?
I’m not sure what you mean… are you saying that on the mios app store there are Ir codes for devices?
Should have been ilearn and too early on the morning here to focus.
Ok I follow - the confusion was that i bought my GC-100 a long time ago and the ihelp and ilearn apps were called something different back then. I do have a GC-IRL which i will use to learn the codes (connect it to my GC-100 and learn from there).
and I believe that when you said the app store you may have meant the mac app store and were referring to the fact that ihelp and ilearn are available in the mac app store… is that correct?
Thanks again for your assistance - i think this is going to work really well and I am looking forward to getting it all up and running ![]()
http://apps.mios.com/index.php?cat=3&npage=1
Should have been stating apps have been developed for various ir controlled devices. I did a secondary check and no there were none there for the one you mentioned.
The ilearn and Ihelp are available from:
Sorry my responses are fragmented but I am giving my kids breakfast and only allows short burst transmissions between their demands.
To state something: I use iRule for controlling my Av system but due to the single user limitation if the gc100 family firmware the Vera really makes this really workable.
Ok so I added a scene, went to advanced, and chose my devices and told it to send the ON command for each. But when I try to run the scene, nothing happens.
I know the gc is working because the controls from the remotes in my Vera Mobike app send the ir successfully and work great.
So did I miss something? Why won’t it work from a scene?
I don’t need to set up a trigger if I am just annually running it right?
There is a limitation with the GC series and that is they can only have one active client. Ensure that your mobile app is still not connected and try again.
I think I found d the problem. If I have a single if. On and in my scene it works fine. But if I add more than one command it fails. I am wondering if I need to add a slight delay between each ir command in a scene? If so, how do i accomplish that?
