First things first:
[b]Always turn off power at the breaker before starting any electrical work. Turning off the switch won’t do it. You can still have line voltage at the fixture (as in your case).
Always adhere to local codes.
If you are in any way unsure of what you are doing, hire an electrician.[/b]
[quote=“integlikewhoa, post:6, topic:196833”][quote=“mullermn, post:5, topic:196833”]Thankyou for the responses.
Sadly it’s 2 wire, so I don’t believe a relay is an option - I’ve got other switches where I am using dimmers in binary ‘on/off’ mode for the same reason. If dimmers aren’t acceptable here (which I have read in other places online too) then this particular project is possibly a non starter. Thanks for the help![/quote]
The lights must have neutral and hot. So a relay up in the light is always an option like what was stated here.
2 wire Z-wave devices are not ideal in alot of cases. Most of the big brands here all stopped making them (no z-wave plus or new versions) due to how picky they are with led or amount of lights. I get they make it easy to install for some but they way they use back feed voltage to try and power up the z-wave model was never ideal.[/quote]
Agreed. You will need a Zwave relay with dry-contact control input like the Aeotec Micro Switch. Put the relay in the fixture near the ballast and connect the switch to the local inputs. The switch becomes a low-voltage dry-contact control with no line voltage or neutral needed. The wall switch will toggle the light with each position change. In other words, any change of state at the switch will cause the light to change state, so the “up” position will not always mean “on” and “down” will not always mean “off”.
This will only work with a simple “line/load” drops to the switch(es) where the wires can be reassigned as low-voltage inputs without disrupting the operation of other loads. This technique can be used in 3-way and 4-way circuits as well but you need to be sure you know what you are doing as there a five ways a 3-way circuit might be wired and eight ways a 4-way circuit might be wired.
An alternative is to connect the relay in the fixture but reconnect the wires to the switch to be hot and neutral. Then install a controller in the wall box and bind it to the relay (binding is better than creating a scene in this case). This way the load is automated and the “switch” appears to work as normal even though it is not directly controlling the load. I do this with pull chain ceiling lights so they can be automated, operated by a wall switch with normal “up=on/down=off” operation, and still toggled on and off by the pull chain attached to the relay input.
The advantage of this method is that the controller does not need to be on the same circuit as the load.
One last thing:
(OK, three last things.)
