Has anyone tried “Controller shift” feature with Leviton handheld controller?
Wiki page says I have to initiate an “Add controller” as usual. But I used to do “Copy Z-Wave network” from Vera and select “Update Controller → Vera” from the controller, which would send its data to Vera and Vera becomes a secondary one. I can’t seem to initiate a controller shift from my remote controller and Vera times out very quickly.
There is a “Join as secondary” option in the Leviton controller. But it erases everything first, and then tries to join a network as a secondary controller.
Ah, apparently I wasn’t reading the description carefully… It appears “Controller shift” function only allows to shift Primary controller status from Vera to another controller, but not the other way around.
Is there any way to shift Primary status to Vera from another controller?
So, what option do you select in Vera? Is it still “Controller shift”? Have you tried shifting roles with Vera in this direction - i.e. from Cooper to Vera to become primary? Thanks.
