control of whr930
@mcvflorin;
i am stil having problems linking the action in the json file (giving a command) and executing the command in the I_ file.
If i create a scene to change the settings to values are changed.
at the moment i want the orders to be excuuted in the I_ file
if i look at different other plugins it should be correct, so pls be so kind to advice
the next step is to use SendCommand to an Network Converter RS232/RS485 to TCP/IP but that is next puzzle
thanks in advance
huib
Did somebody had the chance to look at the command structure?
At the moment i am sort of stuck, so some help /guidance is much appriciated
Rgds
Huib
Thanks,
Wil look into it
Rgds
Huib
I am stil having the following problem on which i need some assistance;
in the I_file i have created an
if i use the same instruction in a scene i can change the corresponding variable
on the screen at the dashboard on the screen i can see the value changing
in the file D_json file i have a button, and attached to this button a link to the action
BUT IT DOES NOT WORK
So could you have a look and advice what i am doing wrong
thanks in advance
huib
In the Json file you use only actions that are not defined in the S_ file. And the only action you defined in the S_ file (Data) is not called anywhere in the Json file.
You must define an action in the S_ file and implement it in the I_ file to use it.
@mcvflorin,
Can you give me an example, based on my files?
Thanks and regards
Huib
@mcvflorin,
I have got working.
Up to next step, communication out and reading data in
Rgds
Huib
Next level;
How can i simulate incoming data
I have a data string in hex (0x07 0xD4 0x06 …)
If i make a string DaraIn with this info which needs to be used
So how can i simulate this DataIn as input from an rs232to ip adapter
And process it as requested.
Pls advice
Huib
It depends. If you use the raw protocol, make a for and call your incoming data handler function for every byte. Otherwise, pass all the data at once to that function.
After a busy periode doing other things, back to the project
I have bought an EZL-70(A) Ethernet-RS232/RS485 10Base-T module to write the communication part of it
At the moment i am having problems with the settings of the ip adress and ports
Somebody using this adapter?
rgds
Huib
After a long periode i have taken up the project up again
if i sent an message to the unit using
	local Start_Byte 			=  string.char(7) .. string.char(240)   --  "07F0"
	local Stop_Byte 			=  string.char(7) .. string.char(15)	--	"070F"
how do change the respond in to ascii?
pls advice
huib
