Control of Thermostat not fully exposed to Vera
I’ve purchased a ZTS-100 Thermostat registered it with the Vera system and what I notice is that most of the front panel entered values are NOT accessible from the Vera interface
The most irritating one is that the Program mode is not accessible (Program, Override, Permanent Override)
So I cant set the thing back to local control under vera control (I want a scene to do this) , and if change it on the front panel the Vera does not know if its because a person or the times changed it.
Less important is is that the time of day schedules and set-points are not accessible (ie wake, leave, home , sleep ) or even what period it is in at this moment
Is this fixable - do other ZWAVE controlled thermostats do this better - or is in fact suggested to control the heater solely via the ZWave (no local control)
An obvious halfway point would be a local thermostat with local control of temperature but no timer. With the Vera just seeing two temperatures (Current and Set) and a heater on/off. Does something like this exist?
I use Horstmann HRT4-ZW which does exactly that. I have them associated directly to the control relays (Horstmann ASR-ZW and Fibaro FGS211). Vera monitors the current temperature and controls the setpoint. All my time schedules are managed using a Program Logic Event Generator (PLEG) plugin.
The setpoint can be adjusted manually on the 'stat and will stay that way until my PLEG logic changes it. The PLEG calculates the required setpoint based on time, home/away, summer/winter, etc. I don’t ever turn the heating off but the setpoint is dropped to 5C for frost-protection.
