ilias
1
Hello.
I have the Vera Edge running UI7 and - among other things - some light switches.
Situation:
Some of the lights do turn on at 06:30 in the morning and turns of at sunrise. Works fine!
Question:
How do I program the scene to turn on the light at 06:30 but only if the sunrise has not occurred already.
Z-Waver
2
In the scene that is scheduled to run at 6:30, go to the LUUP tab and add this
return luup.is_night() == true
This will prevent the scene from running between sunrise and sunset.
ilias
3
Thank’s a lot. That was an easy solution.
Is there a way to check if the time is before or after a specific time?
Pseudo-code:
Only turn on before 19:00
if time > 19:00
return = false
Only run between 19:00 and 20:00
if time > 18:59 $$ time < 20:00
return = true
Even thought the simplest solution has been provided, for future reference:
http://forum.micasaverde.com/index.php?topic=18679
