I’ve been a long-time Vera user/customer (nearly 7 years now), and generally happy. But I’m tired of the tinkering and having to be a semi-technical whiz to work with the thing, as well as the lack of slick products (in particular, in-wall controllers, etc.). I know there’s a lot of stuff out there you can get to work with Vera, but my foray into home automation was for exactly that reason…home automation, not home science project. I have Vera Lites in both my primary and weekend homes, and they’re at a point where they generally run smoothly and do everything I need them to do. But, I can’t get a fancy thermostat (like the color-screen Honeywell) and am stuck with my very reliable, but rather ugly Trane thermostats, my only touch screen wall controller isn’t even a touch screen (Evolve LCD) and using the very-outdated Vera (UI5) web interface to configure the thing up is just a pain. I’ve got a pre-order in for a bRightSwtich, but they just keep delaying and changing their design, and again, it seems like something I’ll have to tinker with if I ever actually receive it. I don’t mean to come off as bashing Vera - the stuff it does it does well. But when something goes awry, I have to put on my geek hat and figure it out myself. This forum has been invaluable, but Vera support just isn’t there. I’m looking for the plug & play experience, and especially design-conscious device compatibility. So…
I’m contemplating going with one of the new mainstream products out there, like Revolv, SmartThings or Wink. Each has pros and cons, and I realize I will likely be giving up some flexibility - you can do virtually anything with Vera if you want to geek out. The Wink is most appealing primarily because of that “Relay” in-wall controller they’re coming out with, but it’s also gotten the poorest reviews in terms of reliability and device compatibility, and it’s the newest. Revolv seems very robust, but there’s no slick in-wall controller available - they tout the Insteon keypads, but I’ve already got a load of Leviton scene controller keypads, which are virtually the same thing, and they’re just not that cool. In this day of color interactive touchscreens, who wants a limited set of blank white push buttons. SmartThings seems the most positively reviewed, but again, no slick wall controller. They all come with multi-protocol support (varying between them), which is also nice, at least until the world settles on a single standard. For example, they all support one or more wifi thermostats without any special plug-in required - you aren’t shackled to a z-wave only thermostat like I am today (at least, to ensure flawless operation).
Vera has been good to me, and I’m hesitant to abandon it, but I’m not seeing the innovation that these new players seem to have. And I’m just tired of looking at that ugly Evolve LCD scene controller in my entry.
Interested in any & all feedback, especially from anyone who has actually used one of the products I mention above.
