Constant Reboots/Restarts (Vera 3) About Every 45 Seconds
The Network heal won’t work, but if Vera is having problems talking to the Primary (on a little daughter-board inside Vera) then I think the Heal itself will fail also, since it uses the same underlying communications mechanisms that ZW_Send_Data does.
What might be interesting is to “count” how many CAN messages you get in a given time period, then power-cycle (literally, not just Reboot) Vera and then repeat that count. In the short amount of logs presented, you have a high number of CAN messages… I’d be interested in the cycle “fixes” that, even if only temporarily.
Any interesting side-note is that some of your sensors are 2-hops away from Vera. Obviously, there are lots of factors that can contribute to this, but I don’t think I have a single sensor that’s more than 1 hop away, and most are direct-connect… then again, I have a LARGE antenna poking out the bottom of Vera since Z-Wave has been a problem for me in the past (2 story, loads of nodes, wood/stucco construction) and I got jack-of-it a few yrs ago and bought the external antenna.
Well I did a network heal before I went out tonight, just for giggles. It said it couldn’t even configure the door lock that is less than 3 feet away from the controller, with no obstructions in between. I then tried a manual “stress test” on the lock.
I took a peak the logs, and I think I found the part that referenced this action…I assume this isn’t good.
02 01/29/14 22:48:07.262 UPDATE MANUAL ROUTE2 10=(nil) <0x2c573680>
02 01/29/14 22:48:07.262 ZW_Send_Data node 10 NO ROUTE (nil) <0x2c573680>
02 01/29/14 22:48:07.263 ZW_Send_Data node 10 NO ROUTE (nil) <0x2c573680>
01 01/29/14 22:48:08.567 got CAN <0x2c973680>
02 01/29/14 22:48:08.568 ZWaveSerial::Send m_iFrameID 6716 got a CAN – Dongle is in a bad state. Wait 1 second before continuing to let it try to recover. <0x2c573680>
02 01/29/14 22:48:10.201 ZWaveNode::HandlePollUpdate_Security_Nonce_Get requeing job#726 :Lock node 10 dev:61 (0x116f008) N:10 P:35 S:5 for node 18 device 79 <0x2c373680>
02 01/29/14 22:48:10.249 ZW_Send_Data node 18 NO ROUTE (nil) <0x2c373680>
02 01/29/14 22:48:12.253 UPDATE MANUAL ROUTE2 10=(nil) <0x2c573680>
02 01/29/14 22:48:12.254 ZW_Send_Data node 10 NO ROUTE (nil) <0x2c573680>
02 01/29/14 22:48:12.255 ZW_Send_Data node 10 NO ROUTE (nil) <0x2c573680>
01 01/29/14 22:48:17.807 got CAN <0x2c973680>
02 01/29/14 22:48:17.808 ZWaveSerial::Send m_iFrameID 6727 got a CAN – Dongle is in a bad state. Wait 1 second before continuing to let it try to recover. <0x2c573680>
06 01/29/14 22:48:18.066 RAServerSync::SendAlert ID 2147483647,PK_Alert:2396548451 sync 0x1107028 for https://cms1.mios.com/alert?PK_AccessPoint=&HW_Key=&DeviceID=47&LocalDate=2014-01-29%2022:48:06&LocalTimestamp=1391053686&AlertType=3&SourceType=3&Argument=5&Format=&Code=ArmMode&Value=Armed&Description=Security%20Armed&Users=<>
01 01/29/14 22:48:19.101 ZWJob_SendData::ReceivedFrame m_cCommandID 25!=25 || m_cCallbackID 191!=190 || m_cType 0!=REQ <0x2c373680>
06 01/29/14 22:48:20.068 Device_Variable::m_szValue_set device: 93 service: urn:micasaverde-com:serviceId:EnergyMetering1 variable: Watts was: 908 now: 1044 #hooks: 0 upnp: 0 v:0xac4bc0/NONE duplicate:0 <0x2c373680>
06 01/29/14 22:48:20.069 Device_Variable::m_szValue_set device: 93 service: urn:micasaverde-com:serviceId:EnergyMetering1 variable: Log was: 908,1009,1244,1391053609,1010 now: 1044,1000,1244,1391053700,1101 #hooks: 0 upnp: 0 v:(nil)/NONE duplicate:0 <0x2c373680>
06 01/29/14 22:48:20.069 Device_Variable::m_szValue_set device: 93 service: urn:micasaverde-com:serviceId:EnergyMetering1 variable: ActualUsage was: 1 now: 1 #hooks: 0 upnp: 0 v:0xac5870/NONE duplicate:1 <0x2c373680>
04 01/29/14 22:48:21.251 <0x2c373680>
02 01/29/14 22:48:21.252 JobHandler::Run job#728 :pollnode_callb #18 dev:79 (0x1101088) N:18 P:20 S:0 is 13.994026000 seconds old <0x2c573680>
02 01/29/14 22:48:21.254 ZW_Send_Data node 18 NO ROUTE (nil) <0x2c573680>
06 01/29/14 22:48:21.298 Device_Variable::m_szValue_set device: 93 service: urn:micasaverde-com:serviceId:EnergyMetering1 variable: KWH was: 81.7480 now: 81.7650 #hooks: 0 upnp: 0 v:0xac51e8/NONE duplicate:0 <0x2c373680>
06 01/29/14 22:48:21.299 Device_Variable::m_szValue_set device: 93 service: urn:micasaverde-com:serviceId:EnergyMetering1 variable: KWHReading was: 1391053669 now: 1391053701 #hooks: 0 upnp: 0 v:(nil)/NONE duplicate:0 <0x2c373680>
01 01/29/14 22:48:21.320 got CAN <0x2c973680>
01 01/29/14 22:48:21.321 ZWaveSerial::Send m_iFrameID 6739 type 0x0 command 0x19 got repeat failure 24 iNumFailedResponse 1 time 16619320 start time 16619277 wait 2000 m_iSendsWithoutReceive 0 <0x2c573680>
06 01/29/14 22:48:21.378 Device_Variable::m_szValue_set device: 94 service: urn:micasaverde-com:serviceId:EnergyMetering1 variable: Watts was: 571 now: 563 #hooks: 0 upnp: 0 v:0xac4bc0/NONE duplicate:0 <0x2c373680>
06 01/29/14 22:48:21.379 Device_Variable::m_szValue_set device: 94 service: urn:micasaverde-com:serviceId:EnergyMetering1 variable: Log was: 571,596,691,1391053669,1070 now: 563,595,691,1391053701,1102 #hooks: 0 upnp: 0 v:(nil)/NONE duplicate:0 <0x2c373680>
06 01/29/14 22:48:21.380 Device_Variable::m_szValue_set device: 94 service: urn:micasaverde-com:serviceId:EnergyMetering1 variable: ActualUsage was: 1 now: 1 #hooks: 0 upnp: 0 v:0xac5870/NONE duplicate:1 <0x2c373680>
02 01/29/14 22:48:21.408 ZW_Send_Data node 10 NO ROUTE (nil) <0x2c373680>
01 01/29/14 22:48:21.457 got CAN <0x2c973680>
02 01/29/14 22:48:21.458 ZWaveSerial::Send m_iFrameID 6744 got a CAN – Dongle is in a bad state. Wait 1 second before continuing to let it try to recover. <0x2c373680>
01 01/29/14 22:48:22.527 got CAN <0x2c973680>
02 01/29/14 22:48:22.528 ZWaveSerial::Send m_iFrameID 6744 got a CAN – Dongle is in a bad state. Wait 1 second before continuing to let it try to recover. <0x2c373680>
02 01/29/14 22:48:23.547 ZWaveSerial::GetFrame 0x2c572bf0 timed out now 1 m_listGetFramePending 1 <0x2c573680>
02 01/29/14 22:48:23.548 ZWaveJobHandler::SendDataAbort got m_iFrameID 0 <0x2c573680>
01 01/29/14 22:48:23.548 ZWaveNode::GetNonce node 18 cannot send request, abort (nil) <0x2c573680>
01 01/29/14 22:48:23.548 ZWaveNode::EncryptFrame m_iFrameID 6738 cannot get nonce node 18 command class 0x20 command 0x2 <0x2c573680>
02 01/29/14 22:48:23.548 ZWaveSerial::Send m_iFrameID 6738 type 0x0 command 0x13 sent ok - can’t encrypt <0x2c573680>
We experienced another restart this evening, once again it seems to happen more frequently when we trigger a scene called “Garage NFC Entry” and it is at night, which causes a PLEG to trigger.
I have attached a fuller amount of logs (well more than 5 min prior to the restart) which occurred around 22:01:50.
MCV Support seems to be a bit lost on the issue, however I have reached back out again. Anyone with insight I would appreciate your thoughts!
I notice these around the time it looks like the unit restarts:
50 02/06/14 22:01:52.131 luup_log:56: PLEG-56:Initialize:Restart <0x2b829680>
50 02/06/14 22:01:54.233 luup_log:58: PLEG-58:Initialize:Restart LEAK this:36864 start:114688 to 0x124e000 <0x2b829680>
06 02/06/14 22:01:54.252 Device_Variable::m_szValue_set device: 58 service: urn:rts-services-com:serviceId:ProgramLogicEG variable: ConditionSatisfied was: None now: None #hooks: 0 upnp: 0 v:0xe67800/NONE duplicate:1 LEAK this:16384 start:131072 to 0x1252000 <0x2b829680>
50 02/06/14 22:01:54.354 luup_log:60: PLEG-60:Initialize:Restart LEAK this:344064 start:475136 to 0x12a6000 <0x2b829680>
06 02/06/14 22:01:54.370 Device_Variable::m_szValue_set device: 60 service: urn:rts-services-com:serviceId:ProgramLogicEG variable: ConditionSatisfied was: None now: None #hooks: 0 upnp: 0 v:0xe67800/NONE duplicate:1 LEAK this:12288 start:487424 to 0x12a9000 <0x2b829680>
06 02/06/14 22:01:54.370 Device_Variable::m_szValue_set device: 60 service: urn:rts-services-com:serviceId:ProgramLogicEG variable: LastConditionChange was: 1391670382 now: 1391742114 #hooks: 0 upnp: 0 v:(nil)/NONE duplicate:0 <0x2b829680>
50 02/06/14 22:01:54.470 luup_log:73: PLEG-73:Initialize:Restart LEAK this:348160 start:835584 to 0x12fe000 <0x2b829680>
06 02/06/14 22:01:54.526 Device_Variable::m_szValue_set device: 73 service: urn:rts-services-com:serviceId:ProgramLogicEG variable: ConditionSatisfied was: None now: None #hooks: 0 upnp: 0 v:0xe67800/NONE duplicate:1 LEAK this:94208 start:929792 to 0x1315000 <0x2b829680>
06 02/06/14 22:01:54.527 Device_Variable::m_szValue_set device: 73 service: urn:rts-services-com:serviceId:ProgramLogicEG variable: LastConditionChange was: 1391738842 now: 1391742114 #hooks: 0 upnp: 0 v:(nil)/NONE duplicate:0 <0x2b829680>
Yep looks like you are out of memory …
I also noted that you seem to have the Energy plugin enabled … This is well know to destabilize your system.
[quote=“RichardTSchaefer, post:24, topic:177789”]Yep looks like you are out of memory …
I also noted that you seem to have the Energy plugin enabled … This is well know to destabilize your system.[/quote]
Thanks for the super quick response Richard!
I actually disabled the ERGY feature form advice from MCV support, however we still have an AEON Labs Home Energy Monitor that I use to at least look at the raw display…I take it that could be eating up the memory still just displaying the data?
Is there a way to see what is eating up memory for the system? Frankly, I didn’t think we had that many devices running…we do have a few PLEG’s setup, however once again, I didn’t think we would be over-tasking the system.
Are you running a Vera Lite ? Vera 2 ? Vera 3 ?
Do you have a USB memory stick installed ?
What does MCV advice ?
[quote=“RichardTSchaefer, post:26, topic:177789”]Are you running a Vera Lite ? Vera 2 ? Vera 3 ?
What does MCV advice ?[/quote]
We have a Vera 3, USB Stick installed.
MCV originally told us the ERGY plugin was causing the issues, so we disabled it. When we continued to have issues, they told us to repair the z-wave network. Issues continued. The told to remove all z-wave locks, and then re-establish them with the system. Still issues. Then told it was the energy sensor was installed incorrectly, and they made some modifications to the system. We removed, and then re-established it with the network.
Most recently they have told us we have had a “memory leak” however I can’t seem to understand if that is being caused by incorrect configuration, bad hardware, or we are simply asking vera to do too much.
MCV support has recommended disabling all PLEGs, and the Ademco Plugin. Frankly, if I disable those two…there is really no reason to have Vera other than home control…rather than automation.
Richard I really appreciate all of your help, it is users like you that make me stick with Vera!
I would probably try the following.
Make a Z-Wave Backup.
Make a Backup.
Reset to Factory Defaults.
Restore With Option to Restore Z-Wave.
I wonder if there is a problem removing the Energy Plugin once installed.
[quote=“RichardTSchaefer, post:28, topic:177789”]I would probably try the following.
Make a Backup.
I wonder if there is a problem removing the Energy Plugin once installed.[/quote]
Sounds a bit scary :slight_smile:
I assume that this will put everything back into place…plegs and all?
If you want to completely clear out ERGY, here are the latest files that it places into [tt]/etc/cmh-ludl/[/tt]:
-rw-r--r-- 1 root root 1289 Jan 30 2013 I_ErgyX300Thermostat.xml -rw-r--r-- 1 root root 354 Jan 30 2013 I_ErgyWebPowerIII.xml -rw-r--r-- 1 root root 124 Jan 30 2013 I_ErgyWattNode.xml -rw-r--r-- 1 root root 183 Jan 30 2013 I_ErgyPM800.xml -rw-r--r-- 1 root root 350 Jan 30 2013 I_ErgyMSNPlug.xml -rw-r--r-- 1 root root 6744 Jan 30 2013 D_EthernetPowerController.json -rw-r--r-- 1 root root 3035 Jan 30 2013 D_ErgyX300Thermostat.xml -rw-r--r-- 1 root root 135 Mar 25 2013 I_ErgyBlueLine.xml -rw-r--r-- 1 root root 659 Mar 25 2013 D_ErgyBlueLine.xml -rw-r--r-- 1 root root 865 Mar 25 2013 S_Irradiance1.xml -rw-r--r-- 1 root root 403 Mar 25 2013 S_ErgyModbus.xml -rw-r--r-- 1 root root 387 Mar 25 2013 I_SimpleLanWaterMeter.xml -rw-r--r-- 1 root root 435 Mar 25 2013 I_EthernetPowerControllerIII.xml -rw-r--r-- 1 root root 125 Mar 25 2013 I_ErgyPVPModbus.xml -rw-r--r-- 1 root root 127 Mar 25 2013 I_ErgyPVM1010.xml -rw-r--r-- 1 root root 212 Mar 25 2013 I_ErgyIR.xml -rw-r--r-- 1 root root 151 Mar 25 2013 I_ErgyEKMMeter.xml -rw-r--r-- 1 root root 780 Mar 25 2013 D_SimpleLanWaterMeter.xml -rw-r--r-- 1 root root 4634 Mar 25 2013 D_SimpleLanWaterMeter.json -rw-r--r-- 1 root root 9424 Mar 25 2013 D_IRSensor1.json -rw-r--r-- 1 root root 905 Mar 25 2013 D_EthernetPowerControllerIII.xml -rw-r--r-- 1 root root 817 Mar 25 2013 D_ErgyWattNode.xml -rw-r--r-- 1 root root 826 Mar 25 2013 D_ErgyPVPModbus.xml -rw-r--r-- 1 root root 658 Mar 25 2013 D_ErgyPVM1010.xml -rw-r--r-- 1 root root 861 Mar 25 2013 D_ErgyPM800.xml -rw-r--r-- 1 root root 543 Mar 25 2013 D_ErgyMSNPlug.xml -rw-r--r-- 1 root root 1054 Mar 25 2013 D_ErgyIR.xml -rw-r--r-- 1 root root 853 Mar 25 2013 D_ErgyEKMMeter.xml -rw-r--r-- 1 root root 128 Mar 25 2013 I_ErgyTED5000.xml -rw-r--r-- 1 root root 122 Mar 25 2013 I_ErgyEGauge.xml -rw-r--r-- 1 root root 546 Mar 25 2013 D_ErgyWebPowerIII.xml -rw-r--r-- 1 root root 869 Mar 25 2013 D_ErgyTED5000.xml -rw-r--r-- 1 root root 811 Mar 25 2013 D_ErgyEGauge.xml -rw-r--r-- 1 root root 776 Jul 22 2013 S_Pulse1.xml -rw-r--r-- 1 root root 376 Jul 22 2013 I_ErgyOmnimeter.xml -rw-r--r-- 1 root root 657 Jul 22 2013 D_PulseMeter1.xml -rw-r--r-- 1 root root 693 Jul 22 2013 D_OmniPulseOutput1.xml -rw-r--r-- 1 root root 5119 Jul 22 2013 D_OmniPulseOutput.json -rw-r--r-- 1 root root 6484 Jul 22 2013 D_ErgyPulseMeter.json -rw-r--r-- 1 root root 914 Jul 22 2013 D_ErgyOmnimeter.xml -rw-r--r-- 1 root root 7083 Jul 22 2013 D_ErgyOmnimeter.json -rw-r--r-- 1 root root 3555 Sep 10 05:46 L_SimpleLanWaterMeter.lua -rw-r--r-- 1 root root 4660 Sep 10 05:46 L_EthernetPowerControllerIII.lua -rw-r--r-- 1 root root 8026 Sep 10 05:46 L_ErgyX300Thermostat.lua -rw-r--r-- 1 root root 3829 Sep 10 05:46 L_ErgyWebPowerIII.lua -rw-r--r-- 1 root root 1951 Sep 10 05:46 L_ErgyWattNode.lua -rw-r--r-- 1 root root 6939 Sep 10 05:46 L_ErgyPVPModbus.lua -rw-r--r-- 1 root root 7543 Sep 10 05:46 L_ErgyPM800.lua -rw-r--r-- 1 root root 12109 Sep 10 05:46 L_ErgyOmnimeter.lua -rw-r--r-- 1 root root 8191 Sep 10 05:46 L_ErgyIR.lua -rw-r--r-- 1 root root 5449 Sep 10 05:46 L_ErgyEGauge.lua -rw-r--r-- 1 root root 5071 Sep 10 05:46 L_ErgyTED5000.lua -rw-r--r-- 1 root root 5395 Sep 10 05:46 L_ErgyPVM1010.lua -rw-r--r-- 1 root root 4899 Sep 10 05:46 L_ErgyMSNPlug.lua -rw-r--r-- 1 root root 2936 Sep 10 05:46 L_ErgyBlueLine.lua -rw-r--r-- 1 root root 7974 Oct 2 03:47 L_ErgyEKMMeter.lua -rw-r--r-- 1 root root 12276 Nov 19 06:16 D_PowerMeter1.json -rw-r--r-- 1 root root 18571 Nov 19 06:16 D_Heater1.json -rw-r--r-- 1 root root 38863 Nov 19 06:16 D_HVAC_ZoneThermostat1.json -rw-r--r-- 1 root root 15300 Nov 19 06:16 D_DimmableLight1.json -rw-r--r-- 1 root root 12809 Nov 19 06:16 D_BinaryLight1.json -rw-r--r-- 1 root root 577 Feb 7 12:02 S_EchoEnergyManager.xml.lzo -rw-r--r-- 1 root root 49054 Feb 7 12:02 L_EchoEnergyManager.lua.lzoenc -rw-r--r-- 1 root root 3560 Feb 7 12:02 J_EchoEnergyManager2.js.lzoenc -rw-r--r-- 1 root root 715 Feb 7 12:02 J_EchoEnergyManager.json.lzo -rw-r--r-- 1 root root 13058 Feb 7 12:02 J_EchoEnergyManager.js.lzoenc -rw-r--r-- 1 root root 526 Feb 7 12:02 I_EchoEnergyManager.xml.lzoenc -rw-r--r-- 1 root root 734 Feb 7 12:02 D_EchoEnergyManager.xml.lzo -rw-r--r-- 1 root root 30753 Feb 7 12:02 extra_ergy_files.tar.gz
I built this as a reference list for disabling/removing ERGY and the list was built using a “clean” VeraLite unit, after simply enabling the ERGY functionality (ERGY Plugin 2.0). There are some questionable overlay files in this list that will raise a few eyebrows, especially in the upgrade case (not the issue at hand), but that’s a different discussion.
Clearing these out will save ~300K of flash from the overlay, and presumably stop wasted stuff being pulled into LuaUPnP memory (although I can’t recall if they pull it all in, or on first-use)
At 22:01:37 the procmgr catches a SEGV (Signal 11) from LuaUPnP, it’s very sudden.
01 2014-2-6 22:1:37 caught signal 11 <0x2b797680>
This is likely the real problem they’re trying to chase down, and why they’re asking you to disable some plugins (presumably to reduce/isolate the complexity of the debug)
Normally this is done in a much more “verbose” (and orderly) type of shutdown. This one is different in that it’s extremely abrupt, which is likely causing them to scratch their heads :wink:
BTW, Looking at the data from Chris’s collector, your memory is running just fine. I’m not sure what Richard saw in the log that had him concerned about memory issues, but I’m sure he’ll chime in with data from your logs shortly.
Here are your memory stats in the minutes before the SEGV occurred (lines shortened for readability):
[code]02/06/14 21:51:33.101 Device_… device: 81 service: urn:cd-jackson-com:serviceId:SystemMonitor variable: memoryTotal was: 127456 now: 127456
02/06/14 21:51:33.102 Device_… device: 81 service: urn:cd-jackson-com:serviceId:SystemMonitor variable: memoryFree was: 76976 now: 76836
02/06/14 21:51:33.103 Device_… device: 81 service: urn:cd-jackson-com:serviceId:SystemMonitor variable: memoryBuffers was: 0 now: 0
02/06/14 21:51:33.104 Device_… device: 81 service: urn:cd-jackson-com:serviceId:SystemMonitor variable: memoryCached was: 22128 now: 22172
02/06/14 21:51:33.111 Device_… device: 81 service: urn:cd-jackson-com:serviceId:SystemMonitor variable: memoryUsed was: 50480 now: 50620
02/06/14 21:51:33.112 Device_… device: 81 service: urn:cd-jackson-com:serviceId:SystemMonitor variable: memoryAvailable was: 99104 now: 99008
02/06/14 21:56:33.101 Device_… device: 81 service: urn:cd-jackson-com:serviceId:SystemMonitor variable: memoryTotal was: 127456 now: 127456
02/06/14 21:56:33.102 Device_… device: 81 service: urn:cd-jackson-com:serviceId:SystemMonitor variable: memoryFree was: 76836 now: 76808
02/06/14 21:56:33.103 Device_… device: 81 service: urn:cd-jackson-com:serviceId:SystemMonitor variable: memoryBuffers was: 0 now: 0
02/06/14 21:56:33.103 Device_… device: 81 service: urn:cd-jackson-com:serviceId:SystemMonitor variable: memoryCached was: 22172 now: 22208
02/06/14 21:56:33.108 Device_… device: 81 service: urn:cd-jackson-com:serviceId:SystemMonitor variable: memoryUsed was: 50620 now: 50648
02/06/14 21:56:33.108 Device_… device: 81 service: urn:cd-jackson-com:serviceId:SystemMonitor variable: memoryAvailable was: 99008 now: 99016
02/06/14 22:01:33.101 Device_… device: 81 service: urn:cd-jackson-com:serviceId:SystemMonitor variable: memoryTotal was: 127456 now: 127456
02/06/14 22:01:33.102 Device_… device: 81 service: urn:cd-jackson-com:serviceId:SystemMonitor variable: memoryFree was: 76808 now: 76652
02/06/14 22:01:33.103 Device_… device: 81 service: urn:cd-jackson-com:serviceId:SystemMonitor variable: memoryBuffers was: 0 now: 0
02/06/14 22:01:33.103 Device_… device: 81 service: urn:cd-jackson-com:serviceId:SystemMonitor variable: memoryCached was: 22208 now: 22300
02/06/14 22:01:33.108 Device_… device: 81 service: urn:cd-jackson-com:serviceId:SystemMonitor variable: memoryUsed was: 50648 now: 50804
02/06/14 22:01:33.109 Device_… device: 81 service: urn:cd-jackson-com:serviceId:SystemMonitor variable: memoryAvailable was: 99016 now: 98952
[/code]
My Vera 3 runs with significantly less free/available memory than yours is reporting, has a lot more active logs, and is merrily ticking along (after much micro-surgery in 2013). Not sure why your memoryBuffers never reports non-Zero, but it’s that way either side of the restart(s)
You are also still getting the Z-Wave CAN problems with the Z-Wave dongle, so the MCV support team should spend some time understanding why those are occurring. I have none of these in my current system, but have had them a few yrs back, and MCV had to spend time diagnosing the problems. I doubt this is causing it to crash, per-se, but the logs should be clean of these.
Ultimately, the MCV support team need to deep dive into why you are seeing the SEGV problem. I can see why they want certain plugins disabled, since they have the last activity just before death but this could just be a co-incidence (without more data it’s hard to id a pattern).
If they’re doing standard development stuff, they’re likely just reducing the variables they have to look at. Just don’t let them off the hook for the real diagnosis once you do disable them :wink:
That said, it’ll be the overall frequency of these crashes/instability that will drive their attention.
When you started the thread, it was every 45 seconds. It’s not clear if that’s gotten generally better or not yet, but having numbers to support your case (frequency of occurrence) would definitely bolster any case being made :wink:
Once again, I am getting faster and more detailed replies from folks here, than from MCV support.
When the have asked me to disable things, it isn’t for troubleshooting. They tend to blame these as the issues, and I need to disable them in order for the unit to work.
As far as the unit restarting every few seconds, we have not had that issue since disabling the ERGY plugin. Now the restarts are less random, and seem to be when we are taking “action” with the system, running a scene, PLEG triggers, etc.
It normally takes a few days for me to hear anything from MCV support, I haven’t received a response to my messages from yesterday. I guess I am being impatient. How do folks normally communicate? I originally opened a case, and we now have quite the long email thread back and forth.
Once again, I really appreciate all the help here!
That’s because you have an interesting scenario to diagnose :wink:
When the have asked me to disable things, it isn't for troubleshooting. They tend to blame these as the issues, and I need to disable them in order for the unit to work.
A few yrs ago, that used to be the "[i]Ping Sensor[/i]" Plugin. Glad to see support has moved on to something else now ;)
But seriously, disabling this stuff is a tool they should only use to localize/address the root problem. MiOS/Vera should never crash in that manner, and things should “just work”…
As far as the unit restarting every few seconds, we have not had that issue since disabling the ERGY plugin. Now the restarts are less random, and seem to be when we are taking "action" with the system, running a scene, PLEG triggers, etc.
At least it's somewhat localizable in nature.
It normally takes a few days for me to hear anything from MCV support, I haven't received a response to my messages from yesterday. I guess I am being impatient. How do folks normally communicate? I originally opened a case, and we now have quite the long email thread back and forth.
Yup, that's the norm for simple stuff. For anything advanced, they're reliant upon a much smaller group of people that can diagnose.... so delays follow. Typically the diagnostics are much more "DIY" than they should be, given the potential [stability] benefits to their platform.
You're welcome.
The reason I thought it might be memory was because how abrupt it was crashing.
Can you also post your PLEG status report … I want to make sure it’s not attached to some extremely active event stream.
Attached is the PLEG status reports for all on the system.
The “Work Wakeup” PLEG is disabled. All others are active.
I doubt that this is PLEG related.
Richard should I combine some of the PLEGs into a single instance? What is a best practice?
I tend to have a PLEG for a category.
  1. Water Management (I have a rain water system, lots of outdoor stuff to worry about freezing, instant hot water at the faucets so people do not let perfectly good cold water go down the drain waiting for hot water. Water is more precious than electricity!
  2. Lighting Management
  3. Security/Home/Away Management
Sorry to digress. Richard, may I ask how you keep the hot water hot at the faucets?
Likewise - maybe a new topic?
