Connecting Vera edge to existing account and network
I currently have an account and a network with a Vera Lite and about 80 devices. I purchased a Vera Edge with the intentions of replacing the Vera Lite with the Edge by reconstructing my network one device at a time. I. e. un-include from Vera Lite and include to the Vera Edge. But I have not even been able to get the Vera Edge up and running. I can log into the edge through it’s IP but once there it prompts me to log into my account and upon doing so I get forwarded to my Vera Lite. The account login page said the edge would be added to the account but it is not. Any attempt to do anything on the Vera Edge is halted by the log in page. How do I connect the Vera Edge to my account but still use both controllers.
First are you on ui7 on the LITE? Are you using Home.getvera.com? That usually covers the problem for alot.
I had the same problem (just poor documentation). Try this : http://forum.micasaverde.com/index.php?topic=28836.msg207889.msg#207889
I am not on UI7 on the lite.
Well thats you problem. ui7 which is on the edge requires a different login on a different website then what ui5 does.
So if you were on UI5 you have been using cp.mios.com website and have an account there
You need to go to home.getvera.com website and create a new login with different password atleast. You can use the same user or the same password but not both at the same time, it will cause confusion if you do!
Create a new account with maybe the same username but different password and then you can get started.
