Confusing Enable/Disable Options
I tried to configure vera so it sends me text messages. I did go to “Users & Account Info”->“User Info” and found what I need. However, “Send a text message to my mobile phone” was grayed out with a check mark set. At least on Windows based systems (which the waste majority of people use) that means this option is not available (because it is grayed out) and the default/last value is on (check mark set). Considering it was disabled I tried to find a way to enable it searching the web, etc. Turns out that you just need to click on the check mark box (which was already checked) to enable it. This is very confusing, at least for people on windows systems. Something to consider when designing the UI.
  • 1
Hi Guys,
If you experience issues with your Vera unit please contact our support department from the page below, and we’ll assist you right away.
http://support.getvera.com/
