Two questions really. The first is the subject line. Running a VP, I manually defined the mountpoint. I have a green light on the GUI, and all appears to be working. But… under the UI7 dataMine tab, I’m showing the following memory:
Disk Space Total (kb)521660
Disk Space Used (kb)104
Disk Space Free (kb)521556 0
Since the USB drive is a 2GB (windows fat32 formatted), I’m guessing I’m not really saving to the USB. I also don’t see any blinking on the LED that’s on the thumbdrive.
Second question that may well be related to the first (or the fact that I’m such a friggin noob)… But of the four channels I’ve defined - all of them watts from Aeon Labs micro switches - I’m getting very few updates. Maybe one or two every 10 min or so.
My logs show this:
50 07/29/16 0:10:36.114 luup_log:206: dataMine: Save Lookup=[] <0x72a14520>
50 07/29/16 0:10:36.114 luup_log:206: dataMine: Save Lookup cnt=0 <0x72a14520>
06 07/29/16 0:10:36.161 Device_Variable::m_szValue_set device: 206 service: urn:cd-jackson-com:serviceId:DataMine1 variable: e[35;1mChannelCnte[0m was: 8 now: 8 #hooks: 0 upnp: 0 skip: 0 v:0x13e6d30/NONE duplicate:1 <0x72a14520>
06 07/29/16 0:10:36.161 Device_Variable::m_szValue_set device: 206 service: urn:cd-jackson-com:serviceId:DataMine1 variable: e[35;1mChannelRece[0m was: 5 now: 4 #hooks: 0 upnp: 0 skip: 0 v:(nil)/NONE duplicate:0 <0x72a14520>
50 07/29/16 0:10:36.163 luup_log:206: dataMine: {"Variables":[{"Service":"urn:micasaverde-com:serviceId:EnergyMetering1","AggregateBy":0,"AggregationType":0,"LastRec":1469765033,"TimeOffset":0,"FixYAxis":0,"FilterMaximum":0,"DrowsyWarning":0,"Type":0,"FilterEnable":0,"Logging":0,"Id":5,"FilterMinimum":0,"DataMultiplier":1,"DataType":0,"DrowsyError":0,"DataOffset":0,"Name":"Kitchen Light - KWH","LastVal":0.916,"FirstRec":0,"Variable":"KWH","Device":16}]} <0x72a14520>
50 07/29/16 0:10:55.889 luup_log:206: dataMine: Saving: D[79] S[urn:micasaverde-com:serviceId:EnergyMetering1] V[ActualUsage] <0x73230520>
50 07/29/16 0:10:55.889 luup_log:206: dataMine: Graph Type = 0 <0x73230520>
50 07/29/16 0:10:55.890 luup_log:206: dataMine: Save Lookup=[] <0x73230520>
50 07/29/16 0:10:55.890 luup_log:206: dataMine: Save Lookup cnt=0 <0x73230520>
06 07/29/16 0:10:55.936 Device_Variable::m_szValue_set device: 206 service: urn:cd-jackson-com:serviceId:DataMine1 variable: e[35;1mChannelCnte[0m was: 8 now: 8 #hooks: 0 upnp: 0 skip: 0 v:0x13e6d30/NONE duplicate:1 <0x73230520>
06 07/29/16 0:10:55.937 Device_Variable::m_szValue_set device: 206 service: urn:cd-jackson-com:serviceId:DataMine1 variable: e[35;1mChannelRece[0m was: 4 now: 3 #hooks: 0 upnp: 0 skip: 0 v:(nil)/NONE duplicate:0 <0x73230520>
50 07/29/16 0:10:55.939 luup_log:206: dataMine: {"Variables":[{"Ghost":false,"Service":"urn:micasaverde-com:serviceId:EnergyMetering1","FilterMinimum":0,"LastHistory":1104516000,"AggregateBy":0,"AggregationType":0,"LastRec":1469763986,"Units":"0","Device":79,"FilterMaximum":0,"DataType":0,"Type":0,"FirstRec":0,"LastVal":1,"Id":3,"FixYAxis":0,"DataMultiplier":1,"DrowsyWarning":0,"DrowsyError":0,"DataOffset":0,"Name":"Master Bathroom Light - ActualUsage","FilterEnable":0,"Logging":0,"Variable":"ActualUsage","historyState":0,"TimeOffset":0}]} <0x73230520>
50 07/29/16 0:11:07.047 luup_log:206: dataMine: Timezone Offset :-14400 <0x72a14520>
50 07/29/16 0:11:07.048 luup_log:206: dataMine: Channel: 2 (Id:2), Start: Thu Jul 28 00:11:07 2016, Stop: Fri Jul 29 00:11:07 2016, AggregateBy: 0, AggregationType: 0 <0x72a14520>
50 07/29/16 0:11:07.052 luup_log:206: dataMine: 1:Unable to open file for read - /dataMine/database/2/raw/2378.txt <0x72a14520>
50 07/29/16 0:11:07.053 luup_log:206: dataMine: 1:Unable to open file for read - /dataMine/database/2/raw/2430.txt <0x72a14520>
50 07/29/16 0:11:07.053 luup_log:206: dataMine: rawData points 0 <0x72a14520>
50 07/29/16 0:11:07.054 luup_log:206: dataMine: Timezone Offset :-14400 <0x72a14520>
50 07/29/16 0:11:07.054 luup_log:206: dataMine: Channel: 8 (Id:8), Start: Thu Jul 28 00:11:07 2016, Stop: Fri Jul 29 00:11:07 2016, AggregateBy: 0, AggregationType: 0 <0x72a14520>
50 07/29/16 0:11:07.059 luup_log:206: dataMine: 1:Unable to open file for read - /dataMine/database/8/raw/2378.txt <0x72a14520>
50 07/29/16 0:11:07.061 luup_log:206: dataMine: 1:Unable to open file for read - /dataMine/database/8/raw/2431.txt <0x72a14520>
50 07/29/16 0:11:07.062 luup_log:206: dataMine: 2:Finished reading files - no more data available/dataMine/database/8/raw/2430.txt <0x72a14520>
50 07/29/16 0:11:07.062 luup_log:206: dataMine: rawData points 101 <0x72a14520>
50 07/29/16 0:11:07.084 luup_log:206: dataMine: Timezone Offset :-14400 <0x72a14520>
50 07/29/16 0:11:07.085 luup_log:206: dataMine: Channel: 1 (Id:1), Start: Thu Jul 28 00:11:07 2016, Stop: Fri Jul 29 00:11:07 2016, AggregateBy: 0, AggregationType: 0 <0x72a14520>
50 07/29/16 0:11:07.090 luup_log:206: dataMine: 1:Unable to open file for read - /dataMine/database/1/raw/2378.txt <0x72a14520>
50 07/29/16 0:11:07.092 luup_log:206: dataMine: 1:Unable to open file for read - /dataMine/database/1/raw/2431.txt <0x72a14520>
50 07/29/16 0:11:07.092 luup_log:206: dataMine: 2:Finished reading files - no more data available/dataMine/database/1/raw/2430.txt <0x72a14520>
50 07/29/16 0:11:07.093 luup_log:206: dataMine: rawData points 101 <0x72a14520>
50 07/29/16 0:11:07.113 luup_log:206: dataMine: Done <0x72a14520>
50 07/29/16 0:11:14.394 luup_log:206: dataMine: Timezone Offset :-14400 <0x72a14520>
50 07/29/16 0:11:14.395 luup_log:206: dataMine: Channel: 2 (Id:2), Start: Thu Jul 28 22:59:54 2016, Stop: Fri Jul 29 00:11:14 2016, AggregateBy: 0, AggregationType: 0 <0x72a14520>
50 07/29/16 0:11:14.399 luup_log:206: dataMine: 1:Unable to open file for read - /dataMine/database/2/raw/2378.txt <0x72a14520>
50 07/29/16 0:11:14.400 luup_log:206: dataMine: 1:Unable to open file for read - /dataMine/database/2/raw/2430.txt <0x72a14520>
50 07/29/16 0:11:14.400 luup_log:206: dataMine: rawData points 0 <0x72a14520>
50 07/29/16 0:11:14.401 luup_log:206: dataMine: Timezone Offset :-14400 <0x72a14520>
50 07/29/16 0:11:14.401 luup_log:206: dataMine: Channel: 8 (Id:8), Start: Thu Jul 28 22:59:54 2016, Stop: Fri Jul 29 00:11:14 2016, AggregateBy: 0, AggregationType: 0 <0x72a14520>
50 07/29/16 0:11:14.406 luup_log:206: dataMine: 1:Unable to open file for read - /dataMine/database/8/raw/2378.txt <0x72a14520>
50 07/29/16 0:11:14.408 luup_log:206: dataMine: 1:Unable to open file for read - /dataMine/database/8/raw/2431.txt <0x72a14520>
50 07/29/16 0:11:14.408 luup_log:206: dataMine: 2:Finished reading files - no more data available/dataMine/database/8/raw/2430.txt <0x72a14520>
50 07/29/16 0:11:14.409 luup_log:206: dataMine: rawData points 103 <0x72a14520>
50 07/29/16 0:11:14.417 luup_log:206: dataMine: Timezone Offset :-14400 <0x72a14520>
50 07/29/16 0:11:14.418 luup_log:206: dataMine: Channel: 1 (Id:1), Start: Thu Jul 28 22:59:54 2016, Stop: Fri Jul 29 00:11:14 2016, AggregateBy: 0, AggregationType: 0 <0x72a14520>
50 07/29/16 0:11:14.423 luup_log:206: dataMine: 1:Unable to open file for read - /dataMine/database/1/raw/2378.txt <0x72a14520>
50 07/29/16 0:11:14.426 luup_log:206: dataMine: 1:Unable to open file for read - /dataMine/database/1/raw/2431.txt <0x72a14520>
50 07/29/16 0:11:14.426 luup_log:206: dataMine: 2:Finished reading files - no more data available/dataMine/database/1/raw/2430.txt <0x72a14520>
50 07/29/16 0:11:14.426 luup_log:206: dataMine: rawData points 103 <0x72a14520>
50 07/29/16 0:11:14.443 luup_log:206: dataMine: Done <0x72a14520>
Is that normal? Or should the updates be more frequent?
