hello !
I have changed my router for a Apple Airport Extreme and my vera3 was setted up to a fixed lan ip address 192.168.1.95 and now I have connected to airport wan port in vera3 and lan and wan port in airport and do not have acess to my vera3.
the lan ip address distributted by airport is in new range…
by wifi directly to vera3 I can not acess too.
vera3 wifi lan appears in my ipad but when I connect prompt by a password and this password I don’t know…
can someone help to have access to my vera3 again ?
thanks !!!
The wifi password of your Vera 3 is under the unit. When connected, you’ll need to go to ip address 192.168.81.1 in your browser.
ok ! I will try.
thanks !!!
Garret, i am in home now and connected to vera3 and using internet but dont have access to your configs one lan port is connected to lan port of my airport. If connect the wan port to router no internet connection is possible
Do you not have access to Vera via wifi? You may have to configure your computer to be on the same network as the wifi network e.g. 192.168.81.2 for ip.
Garret !
you are correct…
I had fixed the lan ip address of vera
then I put my computer lan ip in same range and plug in one of lan port of vera
then I have access and turn all settings in auto mode (factory default)
and now is running ok !
I will start to insert devices…and build my zwave network…
I hope count with all help of this forum
thanks !
