Configuring parameters
I have searched all over trying to figure out how to set a configuration parameter on my Aeon Labs DSC26103-ZWUS. I am new to Vera, on my old system I had to set parameter 80=1 to get the microswitch to report status. Can anyone point me to the place to do this? I run UI7. Is it ‘Advanced’ tab under the device “New service/variable/value”? Please help, i don’t want to mess up my new system.
Tanks
It is on the Device Options tab.
First click Add configuration settings then specify the Variable (number), the Data Size (usually 1-byte dec) and the Desired Value. It may take a couple of restarts before the change takes effect.
perfect
please help
i change the parameter as rexbeckett mention it worked for a while
and now the status not updating again
