Configuring MultiWave PE653 PE953 to Vera - Firmware 3.3
We dont have any specific experience with that router, but it should be compatible.
As a test, after you complete the steps in the wireless setup instructions you can then connect the wireless bridge to your network via a network cable to one of the LAN numbered ports on the bridge. The bridge should then have its own IP address on your network and you should be able to log in and check the settings. This will allow you to see whether the router has connected successfully to your wireless network.
Please also check your security/encryption settings that you specified when configuring the bridge to connect to your wireless network.
Please provide as much information as you can and we will provide additional assistance.
Thanks,
Autelis Staff
