Configuration of Aeon 4-in1
Hello,
I bought this device http://www.aeon-labs.com/site/products/view/7/, configured as it is written here: Aeon 4in1 - MiOS. When I am in test mode(?) I set ‘wakeup interval’ to 240 seconds and ‘poll node at mos once every’ 60 seconds.
If I am in test mode and I hit ‘poll now’ button, then temperature humidity etc. updates, but when I change to normal operation ‘poll now’ does not work and temperature does not updates at all.
Does any one have this sensor and can help ?
Does the temperature never update (you’d have to wait for the wake-up interval)?
There's a topic on this device [url=http://forum.micasaverde.com/index.php/topic,3831.msg19202.html#msg19202]here[/url].
BTW, which Vera firmware version are you running?
Temperature updates only if I press black button on the bottom of sensor or when I send poll comand to sensor. So let’s say I found solution but I am stiil curious If the sensor should update automatically.
Works fine for me, I’ve had one of these for a few months now
