Another favourite forum question concerns using delays in scene Lua. It is tempting to do this with luup.sleep(milliseconds) but this can lead to problems. While luup.sleep(…) is executing, other Vera events can be blocked. A peak of activity at this point can cause a Vera restart. This is one possible cause of unexplained restarts.
Luup provides a more-robust way of achieving delays with luup.call_delay(“callfunction”,secs,“parmstring”). This will call the function named callfunction after a delay of secs seconds and pass it the optional parameter parmstring. The called function must be global (i.e. not local). After the luup.call_delay(…), the main code continues to execute and may terminate. Multiple luup.call_delay(…) calls may be made to the same or different called functions.
For example, the following code turns on a light and then turns it off after ten seconds. You could, of course, do this simply with scene action delays but it’s a stepping stone.
[code]luup.call_action(“urn:upnp-org:serviceId:SwitchPower1”,“SetTarget”,{ newTargetValue=1 },66)
luup.call_delay(“delayOff”,10)
– Main code terminates at this point
– Function to be called after delay
function delayOff()
luup.call_action(“urn:upnp-org:serviceId:SwitchPower1”,“SetTarget”,{ newTargetValue=0},66)
end[/code]
Because the called function is global, it does not have access to any of the local variables in the main part of your code. You could make your variables global but be careful how you name them to avoid side effects with other code. A cleaner approach is to pass them via the optional parameter. This parameter is a string so you will need to convert numeric data for some purposes.
In this example, the device ID of the switch is passed as the parameter.
[code]local dID = 66
luup.call_action(“urn:upnp-org:serviceId:SwitchPower1”,“SetTarget”,{ newTargetValue=1 },dID)
luup.call_delay(“delayOff”,10,dID)
function delayOff(dev)
local devno = tonumber(dev)
luup.call_action(“urn:upnp-org:serviceId:SwitchPower1”,“SetTarget”,{ newTargetValue=0},devno)
end[/code]
The called function can also issue a luup.call_delay(…) to itself. This allows timed sequences to be programmed. The following example will dim a light by 10% every two seconds until it reaches zero.
[code]local dID = 99
luup.call_delay(“delayDim”,2,dID)
function delayDim(dev)
local lls = tonumber((luup.variable_get(“urn:upnp-org:serviceId:Dimming1”, “LoadLevelStatus”, devno)))
local newlls = lls - 10
if newlls < 0 then newlls = 0 end
luup.call_action(“urn:upnp-org:serviceId:Dimming1”, “SetLoadLevelTarget”, {newLoadlevelTarget = newlls}, devno)
if newlls > 0 then luup.call_delay(“delayDim”,2,dev) end
end[/code]
Only one parameter string can be passed to the called function. If you need to pass more than one item, you will need to encode them into the string. Simple numeric items can be passed as a comma-separated list. The next example uses this technique to pass three numeric values. The resulting code will either dim a light down to zero or up to 100% - depending on its level when the scene is run.
local dstep, dtarget
local level = tonumber((luup.variable_get(“urn:upnp-org:serviceId:Dimming1”, “LoadLevelStatus”, dID)))
if level > 50 then
dtarget = 0
dstep = -10
else
dtarget = 100
dstep = 10
local prms = string.format("%d,%d,%d",dID,dtarget,dstep)
luup.call_delay(“delayDim”,2,prms)
function delayDim(parms)
local pdev,ptgt,pstp = string.match(parms,"(%d+),(%d+),([%-%d]+)")
local devno = tonumber(pdev)
local target = tonumber(ptgt)
local step = tonumber(pstp)
local newlls = lls + step
if step > 0 then
if newlls > target then newlls = target end
else
if newlls < target then newlls = target end
if newlls ~= target then luup.call_delay(“delayDim”,2,parms) end
end[/code]
Parameters may also be passed as a serialized table. See Passing a Serialized Table.
I hope some of these examples will help to point the way to a solution for your particular requirements. If not, I recommend taking a look at the Program Logic Event Generator (PLEG) plugin.
