Conditional Scene Execution: Some Examples
One of the most frequent questions on this forum is How do I stop my scene running when… This has been asked and answered for many different types of condition and diligent searching will often find you a solution. To help newcomers to Vera, I am posting a few of the most common scenarios in this thread.
The mechanism for preventing a scene running is simple: You insert Luup code into the scene that returns false if you want the scene blocked or true if you want to allow it to run. You can insert the code in a Trigger’s Luup event to allow or block only that trigger. You can also insert the code into the scene’s main LUUP tab where it will allow or block all triggers and manual operation. You can use a combination of both types for more complex scenarios. UI7 does not currently allow code to be attached to individual triggers so only the main Luup Code tab may be used.
Day or Night conditions
To allow a scene to run only at night:
return luup.is_night()
To prevent a scene running at night:
return not luup.is_night()
Or a more generic form:
local allow = true -- true runs scene at night, false blocks it return ((luup.is_night()) == allow)
Many of us use the DayTime (Day or Night) plugin as an alternative to the luup.is_night() function. It has a few advantages: You can configure offsets from sunrise and sunset to control your definition of daytime; You can manually set it to Day or Night to test your scenes; It gives you an indicator on your dashboard to show its current state.
Generic DayTime:
local dID = 23 -- Device ID of your DayTime plugin local allow = true -- true runs scene during daytime, false runs it at night local status = luup.variable_get("urn:rts-services-com:serviceId:DayTime","Status",dID) return ((status == "1") == allow)
Other examples
Z-Wave and Virtual Switches
Time Period
Temperature Range
Humidity Range
Light Level
VariableContainer
Day Range
Date Range
Multiple Conditions
Using Functions
Multiple Triggers
Time Window
Service IDs, Variables and Actions
Delayed Actions
Delayed Actions - Passing a Serialized Table
Debugging Lua Code - kwikLog
Testing Lua Code - LuaTest
Run Scene when a Variable Changes
Finding the Correct Service ID
We often want to allow or block scenes depending on the state of a Z-Wave switch (E.g. a light is on) or a VirtualSwitch (e.g. Home/Away). The VirtualSwitch (VS) plugin is very useful as a means of controlling scenes. You can create several different VS devices to signify various states of your home. E.g. Home/Away, OnVacation, HaveGuests, etc. VS devices can be set manually through the UI, by scenes or with other plugins.
Testing the state of a switch is essentially the same whether it is real or virtual but the serviceID must match the type of switch being tested.
Z-Wave Switch:
local dID = 66 -- Device ID of your Z-Wave Switch local allow = true -- true runs scene if switch is on, false blocks it local status = luup.variable_get("urn:upnp-org:serviceId:SwitchPower1","Status",dID) return ((status == "1") == allow)
Virtual Switch:
local dID = 32 -- Device ID of your VirtualSwitch local allow = true -- true runs scene if switch is on, false blocks it local status = luup.variable_get("urn:upnp-org:serviceId:VSwitch1","Status",dID) return ((status == "1") == allow)
MultiSwitch:
local dID = 94 -- Device ID of your MultiSwitch local button = 1 -- MultiSwitch button number (1-8) local allow = true -- true runs scene if switch is on, false blocks it local status = luup.variable_get("urn:dcineco-com:serviceId:MSwitch1","Status"..button,dID) return ((status == "1") == allow)
We frequently want to control the time periods during which a scene may run. You would probably prefer that your bedroom light did not come on in the middle of the night when you are clocked by the motion-sensor on your way to the bathroom. ;D
Here is a generic routine that can be set to allow or block a scene in the period between two times. The start and end times can be set within the same day or either side of midnight. Both times must be in 24-hour form and entered as HH:MM. As with previous generic examples, the variable allow determines whether to allow or block the scene during the specified period.
Generic Time Period:
local pStart = "22:30" -- Start of time period local pEnd = "06:15" -- End of time period local allow = true -- true runs scene during period, false blocks it local hS, mS = string.match(pStart,"(%d+)%:(%d+)") local mStart = (hS * 60) + mS local hE, mE = string.match(pEnd,"(%d+)%:(%d+)") local mEnd = (hE * 60) + mE local tNow = os.date("*t") local mNow = (tNow.hour * 60) + tNow.min if mEnd >= mStart then return (((mNow >= mStart) and (mNow <= mEnd)) == allow) else return (((mNow >= mStart) or (mNow <= mEnd)) == allow) end
With a small modification, we can take the start time as sunset with a +/- offset. Strictly speaking, this will use the time of the next sunset so will give a slightly different result before and after sunset. The difference is about two minutes so should not be a major problem.
Sunset to End Time:
local pStart = 0 -- Start of time period, minutes offset from sunset local pEnd = "06:15" -- End of time period local allow = true -- true runs scene during period, false blocks it local mStart = math.floor( (luup.sunset() % 86400) / 60 ) + pStart local hE, mE = string.match(pEnd,"(%d+)%:(%d+)") local mEnd = (hE * 60) + mE local tNow = os.date("*t") local mNow = (tNow.hour * 60) + tNow.min if mEnd >= mStart then return (((mNow >= mStart) and (mNow <= mEnd)) == allow) else return (((mNow >= mStart) or (mNow <= mEnd)) == allow) end
We can also use sunrise as one of our times. This version has a specified start time and the end time is sunrise with a +/- minutes offset.
Start Time to Sunrise:
local pStart = "22:30" -- Start of time period local pEnd = 0 -- End of time period, minutes offset from sunrise local allow = true -- true runs scene during period, false blocks it local hS, mS = string.match(pStart,"(%d+)%:(%d+)") local mStart = (hS * 60) + mS local mEnd = math.floor( (luup.sunrise() % 86400) / 60 ) + pEnd local tNow = os.date("*t") local mNow = (tNow.hour * 60) + tNow.min if mEnd >= mStart then return (((mNow >= mStart) and (mNow <= mEnd)) == allow) else return (((mNow >= mStart) or (mNow <= mEnd)) == allow) end
This code will enable you to set a range of temperatures within which your scene will, or will not, be run. Set tLow and tHigh to define the range. As with previous generic examples, the variable allow determines whether to allow or block the scene when the current temperature is within the specified range.
Generic Temperature Range:
local dID = 55 -- Device ID of your thermostatic/temperature sensor local tLow = 18 -- Lowest temperature of range local tHigh = 22 -- Highest temperature of range local allow = true -- true runs scene when in range, false blocks it local tCurrent = tonumber((luup.variable_get("urn:upnp-org:serviceId:TemperatureSensor1","CurrentTemperature",dID))) return (((tCurrent >= tLow) and (tCurrent <= tHigh)) == allow)
Coming next: Humidity Range
This code will enable you to set a range of humidity within which your scene will, or will not, be run. Set hLow and hHigh to define the range. As with previous generic examples, the variable allow determines whether to allow or block the scene when the current humidity level is within the specified range.
Generic Humidity Range:
local dID = 31 -- Device ID of your humidity sensor local hLow = 50 -- Lowest humidity of range local hHigh = 80 -- Highest humidity of range local allow = true -- true runs scene when in range, false blocks it local hCurrent = tonumber((luup.variable_get("urn:micasaverde-com:serviceId:HumiditySensor1","CurrentLevel",dID))) return (((hCurrent >= hLow) and (hCurrent <= hHigh)) == allow)
Coming next: Light Level
This code will enable you to set a range of light level within which your scene will, or will not, be run. Set lLow and lHigh to define the range. As with previous generic examples, the variable allow determines whether to allow or block the scene when the current light level is within the specified range.
Generic Light Level Range:
local dID = 30 -- Device ID of your light sensor local lLow = 0 -- Lowest level of range local lHigh = 20 -- Highest level of range local allow = true -- true runs scene when in range, false blocks it local lCurrent = tonumber((luup.variable_get("urn:micasaverde-com:serviceId:LightSensor1","CurrentLevel",dID))) return (((lCurrent >= lLow) and (lCurrent <= lHigh)) == allow)
Coming next: VariableContainer
The VariableContainer (VC) plugin provides a convenient way in which values may be entered and changed without requiring a Vera restart. It also provides a form of scratchpad that can be used to convey values from one scene or plugin to another.
This code will enable you to set a range of values in a VC variable within which your scene will, or will not, be run. Set vLow and vHigh to define the range and vNo to define the VC variable number (1-5) in which the value is stored. As with previous generic examples, the variable allow determines whether to allow or block the scene when the VC variable value is within the specified range.
Generic VirtualContainer Value Range:
local dID = 76 -- Device ID of your VariableContainer local vNo = 5 -- Variable number (1-5) to test local vLow = 100 -- Lowest value of range local vHigh = 199 -- Highest value of range local allow = true -- true runs scene when in range, false blocks it local sVC = luup.variable_get("urn:upnp-org:serviceId:VContainer1","Variable" .. vNo,dID) local vVC = tonumber(sVC) or 0 return (((vVC >= vLow) and (vVC <= vHigh)) == allow)
Another great use for VC is to allow us to change the limits in our scene Luup without restarting Vera. The following code tests for the current time to be within the period set by two VC variables. These variables must contain valid times in HH:MM form. Other than taking the Start and Stop times from VC variables, this code works the same as the earlier Time Range example.
Generic Time Range from VC Variables:
local dID = 76 -- Device ID of your VariableContainer local vStart = 4 -- Variable number (1-5) of Start time local vEnd = 5 -- Variable number (1-5) of End time local allow = true -- true runs scene when during time range, false blocks it local pStart = luup.variable_get("urn:upnp-org:serviceId:VContainer1","Variable" .. vStart,dID) or "" if #pStart == 0 then pStart = "00:00" end local pEnd = luup.variable_get("urn:upnp-org:serviceId:VContainer1","Variable" .. vEnd,dID) or "" if #pEnd == 0 then pEnd = "00:00" end local hS, mS = string.match(pStart,"(%d+)%:(%d+)") local mStart = (hS * 60) + mS local hE, mE = string.match(pEnd,"(%d+)%:(%d+)") local mEnd = (hE * 60) + mE local tNow = os.date("*t") local mNow = (tNow.hour * 60) + tNow.min if mEnd >= mStart then return (((mNow >= mStart) and (mNow <= mEnd)) == allow) else return (((mNow >= mStart) or (mNow <= mEnd)) == allow) end
This code will enable you to set a range of days during which your scene will, or will not, be run. Set dFirst and dLast to define the range. These are day numbers (1-7) where 1 is Sunday. As with previous generic examples, the variable allow determines whether to allow or block the scene when the current day is within the specified range.
Generic Day Range:
local dFirst = 2 -- Start day of period (1-7) Sunday = 1 local dLast = 6 -- End day of period (1-7) Sunday = 1 local allow = true -- true runs scene during period, false blocks it local tNow = os.date("*t") local dNow = tNow.wday if dLast >= dFirst then return (((dNow >= dFirst) and (dNow <= dLast)) == allow) else return (((dNow >= dFirst) or (dNow <= dLast)) == allow) end
This code will enable you to set a range of dates during which your scene will, or will not, be run. Set mdStart and mdEnd to define the range. These are dates in the form of MM/DD (in deference to our US members). The included period may span the change of year if required. As with previous generic examples, the variable allow determines whether to allow or block the scene when the current date is within the specified range.
Generic Date Range:
local mdStart = "12/01" -- Start of period (MM/DD) local mdEnd = "12/31" -- End of period (MM/DD) local allow = true -- true runs scene during period, false blocks it local smS, sdS = string.match(mdStart,"(%d+)%/(%d+)") local smE, sdE = string.match(mdEnd,"(%d+)%/(%d+)") local mS = tonumber(smS) local dS = tonumber(sdS) local mE = tonumber(smE) local dE = tonumber(sdE) local tNow = os.date("*t") local mN = tNow.month local dN = tNow.day if (mE > mS) or ((mE == mS) and (dE >= dS)) then return (((mN > mS) or ((mN == mS) and (dN >= dS))) and ((mN < mE) or ((mN == mE) and (dN <= dE))) == allow) else return (((mN > mS) or ((mN == mS) and (dN >= dS))) or ((mN < mE) or ((mN == mE) and (dN <= dE))) == allow) end
If the preceding examples don’t cover what you want to achieve:
Try the good old search facility. There’s a very good chance that someone else had a similar requirement and found a solution. Google search with site:forum.micasaverde.com may give you better results than the forum’s own search-engine.
You may need to combine more than one piece of code. This can be done by using a variable to hold the result of one test and and-ing or or-ing it with another. For example, to run a scene when a temperature is within a range but only during the day, try this:
[code]local isDay = not luup.is_night()
local dID = 55 – Device ID of your thermostatic/temperature sensor
local tLow = 18 – Lowest temperature of range
local tHigh = 22 – Highest temperature of range
local allow = true – true runs scene when in range, false blocks it
local tCurrent = tonumber((luup.variable_get(“urn:upnp-org:serviceId:TemperatureSensor1”,“CurrentTemperature”,dID)))
return (((tCurrent >= tLow) and (tCurrent <= tHigh)) == allow) and isDay[/code]
If that still isn’t enough, you should probably be considering the Program Logic Event Generator (PLEG) plugin. This has been designed to make complex logic simple to implement. It is particularly good for handling situations where the order or timing of events is important. It also provides highly-flexible schedules with optional random elements and it will maintain those schedules despite Vera restarts. Learning to use PLEG will almost certainly inspire you to add a level of sophistication to your automation that you never dreamed possible. 8)
Excellent job !!!
Thank you so much for doing this. (Karma Points heading your way)
If you’re feeling up to it, a brief tutorial on functions would be much appreciated too.
You can combine multiple conditions in scene or trigger Luup by converting each piece of code into a Lua function. Then you can combine the results of each test in a single return statement using and/or operators.
Converting to a function is easy:
local function functionName() <lines of code> end
Combining the results is also simple:
return function1() and function2()
Example to allow a scene to run between 08:00 and 22:30 at weekends:
[code]local function checkTime()
local pStart = “08:00” – Start of time period
local pEnd = “22:30” – End of time period
local allow = true – true runs scene during period, false blocks it
else
local function checkDay()
local dFirst = 7 – Start day of period (1-7) Sunday = 1
local dLast = 1 – End day of period (1-7) Sunday = 1
else
return checkTime() and checkDay()[/code]
Fantastic work!. This should be recommended reading for everyone and should be made sticky.
Made this topic a stick. To make things easier, can we have some sort of index on the first post pointing to each post? This will allow a member to click and go strait to the post without having to scroll and work through other posts that other members reply to.
  • Garrett
[quote=“garrettwp, post:14, topic:178331”]Made this topic a stick. To make things easier, can we have some sort of index on the first post pointing to each post? This will allow a member to click and go strait to the post without having to scroll and work through other posts that other members reply to.
  • Garrett[/quote]
    Thanks for making this a sticky, Garrett. The index is a good idea - duly added.
I showed in Multiple Conditions how a code chunk could be converted to a function. With small adjustments, the function call can pass the parameters to be used for the test. Now a single piece of code can be used to test several devices. The function code can even be added to your Startup Lua so it may be called from any scene. In the following examples, I changed the original lines that set the parameters to comments (with --) as a reminder of what each parameter means.
Function to check if a temperature is within a range
function checkTemp(dID, tLow, tHigh, allow) --dID = 55 -- Device ID of your thermostatic/temperature sensor --local tLow = 18 -- Lowest temperature of range --local tHigh = 22 -- Highest temperature of range --local allow = true -- true runs scene when in range, false blocks it local tCurrent = tonumber((luup.variable_get( "urn:upnp-org:serviceId:TemperatureSensor1","CurrentTemperature",dID))) return (((tCurrent >= tLow) and (tCurrent <= tHigh)) == allow) end
Function to check the state of a Z-Wave switch
function checkSwitch(dID, allow) --local dID = 66 -- Device ID of your Z-Wave Switch --local allow = true -- true runs scene if switch is on, false blocks it local status = luup.variable_get("urn:upnp-org:serviceId:SwitchPower1","Status",dID) return ((status == "1") == allow) end
We can use these two functions to implement a more-complex set of conditions. This example, suggested by @parkerc, checks the temperature in three different rooms. If any of the temperatures are out of range, checkTemp(device,min,max,true) returns false. In this case we check if the switch controlling our heating is off and, if so, allow the scene to run to turn it on.
if checkTemp(123,18,22,true) and checkTemp(124,18,22,true) and checkTemp(125,18,22,true) then return false -- All temperatures are in range, don't run scene else return checkSwitch(101,false) -- Run scene if switch is off end
Adding functions to Startup Lua
Select the APPS tab, click on Develop Apps and select Edit Startup Lua. Add your functions to the end of the existing code and click GO. Now click on Vera’s Reload button to restart the luup engine. Your functions should now be available to the luup in any scene.
Sometimes we want to have several different events or schedules result in essentially the same action but with different settings. An example would be setting different temperature setpoints or dimmer levels depending and time schedules or any of the conditions in the previous examples. The obvious way to do this is with several scenes but there is another way. We can use a global variable to transport our required settings from Trigger Luup event to the main scene LUUP.
This example is for a scene that sets a Thermostat setpoint based on one of three triggers.
Trigger 1 Luup event - Set to 20 during daytime, do nothing at night
[code]local function checkDayTime()
local dID = 23 – Device ID of your DayTime plugin
local allow = true – true runs scene during daytime, false runs it at night
local status = luup.variable_get(“urn:rts-services-com:serviceId:DayTime”,“Status”,dID)
return ((status == “1”) == allow)
if checkDayTime() then
setTemp = 20
return true
else
return false
[/code]
Trigger 2 Luup event - Set to 20 during daytime or 10 at night
setTemp = 20
else
setTemp = 10
return true
[/code]
Trigger 3 Luup event - Set to 18
setTemp = 18 return true
Main scene LUUP - Version 1
local dID = 55 if (setTemp ~= nil) then luup.call_action("urn:upnp-org:serviceId:TemperatureSetpoint1_Heat","SetCurrentSetpoint",{NewCurrentSetpoint=setTemp},dID) setTemp = nil end
Main scene LUUP - Version 2
local dID = 55 if (setTemp == nil) then setTemp = 20 end luup.call_action("urn:upnp-org:serviceId:TemperatureSetpoint1_Heat","SetCurrentSetpoint",{NewCurrentSetpoint=setTemp},dID) setTemp = nil
Version 1 of the Main scene LUUP will do nothing if run from the UI because, if a trigger did not occur, setTemp will be nil. Version 2, if run from the UI, will set the temperature setpoint to 20.
There were two requests for this type of scene condition in the last 24 hours so it must be worth posting here. The objective is to allow or prevent a scene executing when triggers occur in a short time period (window).
All these examples save a timestamp each time they are run using a global variable tLastOnD99. On each run, the saved timestamp is subtracted from the current time and compared to the specified time window (twSecs). To allow this code to be used for more than one triggering device, the 99 in tLastOnD99 should be replaced with the device ID of the triggering device. This is simply to avoid undesired side effects so any other name could be used instead.
As with previous examples, the code may be placed in either a Trigger’s Luup event to allow/prevent that trigger or on the scene’s LUUP tab where it will affect all triggers and manual operation.
Allow the scene to run when a trigger occurs within twSecs of the last one (e.g. on/off/on):
local twSecs = 5 -- Number of seconds in time window local tNow = os.time() local tLastOn = tLastOnD99 or 0 tLastOnD99 = tNow return ((tNow - tLastOn) <= twSecs)
Allow the scene to run provided a trigger occurs at least twSecs after the last one:
local twSecs = 5 -- Number of seconds in time window local tNow = os.time() local tLastOn = tLastOnD99 or 0 tLastOnD99 = tNow return ((tNow - tLastOn) >= twSecs)
Generic version:
local twSecs = 5 -- Number of seconds in time window local allow = true -- true runs scene during time window, false blocks it local tNow = os.time() local tLastOn = tLastOnD99 or 0 tLastOnD99 = tNow return (((tNow - tLastOn) <= twSecs) == allow)
One of the most frequent problems we see in requests for help with Lua code, is errors in Service IDs and variable or parameter names in luup function calls. These errors can be tricky to find. Even one character in the wrong case will prevent the call working correctly: A luup.variable_get(…) will return a nil instead of the expected value; A luup.call_action(…) may do absolutely nothing.
Listed below are example luup calls for the most common device types. All examples assume that local variable dID contains the ID of the device being addressed. e.g. local dID = 123 Alternatively, replace dID in the calls with the required device ID number. Examples are given for reading a device variable using luup.variable_get(…) and for initiating an action with luup.call_action(…). It is also possible to directly set device variables but, in many cases, this will have little or no apparent effect on the device. Generally it is better to use luup.call_action(…) rather than directly setting device variables.
The examples are also in the attached pdf file. If you drop it on your desktop, you can quickly open it to copy and paste the calls into your Lua. If the device you want to address is not listed, you can find the Service ID by hovering the mouse cursor over the name of the variable on the device’s Advanced tab.
On/Off Switch
Set Target, read Status. “0” = Off, “1” = On.
[code]local status = luup.variable_get(“urn:upnp-org:serviceId:SwitchPower1”, “Status”, dID)
luup.call_action(“urn:upnp-org:serviceId:SwitchPower1”, “SetTarget”, {newTargetValue = “1”}, dID)[/code]
Virtual Switch
[code]local status = luup.variable_get(“urn:upnp-org:serviceId:VSwitch1”, “Status”, dID)
luup.call_action(“urn:upnp-org:serviceId:VSwitch1”, “SetTarget”, {newTargetValue = “1”}, dID)[/code]
Dimmable Light
Set LoadLevelTarget, read LoadLevelStatus. “0” = Off, “100” = Full.
[code]local level = luup.variable_get(“urn:upnp-org:serviceId:Dimming1”, “LoadLevelStatus”, dID)
luup.call_action(“urn:upnp-org:serviceId:Dimming1”, “SetLoadLevelTarget”, {newLoadlevelTarget = “50”}, dID)[/code]
Thermostat
Set ModeTarget, read ModeStatus. “Off”, “HeatOn”, “CoolOn”, “AutoChangeOver”.
[code]local mode = luup.variable_get(“urn:upnp-org:serviceId:HVAC_UserOperatingMode1”, “ModeStatus”, dID)
luup.call_action(“urn:upnp-org:serviceId:HVAC_UserOperatingMode1”, “SetModeTarget”, {NewModeTarget = “Off”}, dID)[/code]
Set and read CurrentSetpoint. (Degrees)
[code]local setpoint = luup.variable_get(“urn:upnp-org:serviceId:TemperatureSetpoint1_Heat”, “CurrentSetpoint”, dID)
luup.call_action(“urn:upnp-org:serviceId:TemperatureSetpoint1_Heat”, “SetCurrentSetpoint”, {NewCurrentSetpoint = “25”}, dID)
local setpoint = luup.variable_get(“urn:upnp-org:serviceId:TemperatureSetpoint1_Cool”, “CurrentSetpoint”, dID)
luup.call_action(“urn:upnp-org:serviceId:TemperatureSetpoint1_Cool”, “SetCurrentSetpoint”, {NewCurrentSetpoint = “30”}, dID)[/code]
Temperature Sensor
local temp = luup.variable_get("urn:upnp-org:serviceId:TemperatureSensor1", "CurrentTemperature", dID)
Generic Sensor
local level = luup.variable_get("urn:micasaverde-com:serviceId:GenericSensor1", "CurrentLevel", dID)
Light Sensor
local level = luup.variable_get("urn:micasaverde-com:serviceId:LightSensor1", "CurrentLevel", dID)
Humidity Sensor
local level = luup.variable_get("urn:micasaverde-com:serviceId:HumiditySensor1", "CurrentLevel", dID)
Security Sensor
[code]local tripped = luup.variable_get(“urn:micasaverde-com:serviceId:SecuritySensor1”, “Tripped”, dID)
local armed = luup.variable_get(“urn:micasaverde-com:serviceId:SecuritySensor1”, “Armed”, dID)
local lasttrip = luup.variable_get(“urn:micasaverde-com:serviceId:SecuritySensor1”, “LastTrip”, dID)
luup.call_action(“urn:micasaverde-com:serviceId:SecuritySensor1”, “SetArmed”, {newArmedValue = “1”}, dID)[/code]
Window Covering
Use Dimmable Light Status variable for current position. Down = 0, Up = 100.
luup.call_action(“urn:upnp-org:serviceId:WindowCovering1”, “Up”, {}, dID)
luup.call_action(“urn:upnp-org:serviceId:WindowCovering1”, “Down”, {}, dID)
luup.call_action(“urn:upnp-org:serviceId:WindowCovering1”, “Stop”, {}, dID)[/code]
Variable Container
Set and read VariableN where N is 1 to 5.
[code]local vcvar1 = luup.variable_get(“urn:upnp-org:serviceId:VContainer1”, “Variable1”, dID)
luup.variable_set(“urn:upnp-org:serviceId:VContainer1”, “Variable1”,newvalue, dID)
luup.variable_set(“urn:upnp-org:serviceId:VContainer1”, “Variable5”,“newtext”, dID)[/code]
DayTime plugin
Set and read Status. “0” = Night, “1” = Day.
[code]local itsday = luup.variable_get(“urn:rts-services-com:serviceId:DayTime”, “Status”, dID)
luup.variable_set(“urn:rts-services-com:serviceId:DayTime”, “Status”, “1”, dID)[/code]
Edit: 13/05/2014 08:50 Corrected typo in DayTime example.
Then other was I forget to cover is drilling into the device utilising lu_invoke function. It will eventually display the service ID and actions available for the selected device.
http://vera.IP.address/port_3480/data_request?id=lu_invoke
