Any plans to support conditional logic?
For example, with my X10 system I have the following configuration:
X10 Wall Switch that controls my upstairs hallway lights.
2 x10 motion detectors; 1 at the bottom of the stairs, the 2nd in the upstairs hallway
I then created several conditional events for turning off the hallway light. The off event is only triggered if both motion sensors haven’t detected motion of XX amount of time. I also have separate on events that are triggered only if a “not bedtime” variable (triggered by a scene - x10 command) is not set to true. This allows me to suppress the hall lights from turning on if I get up in the middle of the night.
