[quote=“Igroup, post:30, topic:190809”]This is the Wiki micasaverde link:
http://wiki.micasaverde.com/index.php/UI_Notes
This says:
"Local web access over your home network
Again, if you check the box “Only allow access through the secure FindVera service”, this is not an issue, and you may skip this topic.
By default, Vera comes with no security on your home’s local network. That means that any other computers within your home, on your local network, or connected to your home network with Wi-Fi, can access and control Vera. So, if someone comes into your home and connects to your home network, or if they hack into your Wi-Fi network, or if you have another router acting as a firewall and it becomes compromised, users can control Vera.
If this is a concern, there are a couple preventive measures you can take besides only allowing access through the FindVera service.
On the Users tab, you can create user names and passwords and check the box “Require a username and password to access Vera from within my home network.” This means that even for people within the home, a username and password will be required. This makes Vera as secure as most any other IP device on your home network that requires a username or password. But that is not truly secure. Unlike the FindVera service which uses special encryption like online banking (SSL), you don’t have any special encryption on your home network. So, if somebody hacked into your home network and was able to monitor your network traffic while you logged into Vera, someone who knew about network protocols could get your user username and password to Vera. "
Well, there is not much but this forum help on UI7. These options don’t exist on UI7, and that’s what I was going for.
Sorry for the confusion, I should be more specific, but I lost track at one point.
I do appreciate the help. “Buggy UI7” stands for actions that I’ve seen and apply and failed (see my network reset to default), and by looking on all firmware upgrades (Critical / Improvements). And once again, the system controls your house, your lights - doors ,appliances and so on. It’s not your home computer that has something significant to hide, is the gateway access to your home.
About my network security, I’m pretty sure that I’m fine, but it looks that you do not understand the risk that Vera gets exposed too. That’s not only internal, but also external, through any other devices connected to the same network.
I can’t find more info on the new UI7 about this, so this could be something that changed.[/quote]
The link you posted Does refrence everything to mios.com which is old ui5 stuff, so that could be one problem… But I searched for several keywords you copied and pasted and I don’t see that information anywhere on the link/page above. Maybe it’s on a different page then what you linked. is UI_notes the write section?
I started with ui5 and have experience with it, but it has been a year since I last ran it so things maybe foggy. I don’t remember that in UI5 either.
I’m still a little confused (maybe your not) on how vera will know who’s using a local computer (or device) and know when to ask for a user and password or not ask for a user an password based on the check mark under their account like you say? How does vera know if my I’m using my computer (laptop or desktop on local network) my kid is using it or a hacker has infuriated my computer? The only option I see is to always request a login (user and password)… Which is an option already.
That's not only internal, but also external, through any other devices connected to the same network.
It connects loosely to other things on your network, which you allow in and have control of..... Security I mean. If you have device you don't trust on your local network then you have an insecure network and that should be delt with. Basically As long as you make sure all your devices on your network have a secure connection going out of the house all you have to do is what the parameter. You shouldn't need to close and local all interior doors of the house when you leave. Just lock and secure all the exterior doors and windows.
This is why vera allows for either free local access (inside your house) or you can secure it making you check in threw a user portal. Your choice.
