I have searched frequently for the best solution to what I would like to do and being rather new to programming scenes, etc. I seem to be even more confused the more I read. I suspect the answer is already posted somewhere but I just haven’t searched for the right words.
Here is what I want involved in this kitchen scene
Outdoor Light Sensor
Motion Sensor
Sink Light (DimmerSwitch)
Breakfast Nook Light (BinaryLight)
Kitchen Light (BinaryLight)
What I have right now is a scene triggered by motion which sets the Sink light to 10% and then runs the following LUUP code added to the scene:
local CarportLightLvl = luup.variable_get(“urn:micasaverde-com:serviceId:LightSensor1”, “CurrentLevel”, 25)
if (tonumber(CarportLightLvl) > 10) then
return false
else
luup.call_delay(‘KitchenSinkLightOff’, 90)
function KitchenSinkLightOff()
luup.call_action(“urn:upnp-org:serviceId:SwitchPower1”, “SetTarget”, {newTargetValue=“0”}, 27)
And that works well as a “night light” when I go into the kitchen at night, but I’d like to do the following as well:
- Not turn on the Sink light if any of the lights are already on.
- Not turn off the Sink light if it has been operated manually after it was turned on by the scene.
- Turn off the Sink light if either of the other two lights are turned on after the scene is triggered by motion.
- And if I can even more fancy, turn off all the lights after X minutes, one at a time followed by a short delay in between each getting turned off (this would be basically a means to “alert” an occupant of the kitchen to do something to reset/restart the scene so they aren’t left in the dark).
Seems to me the best approach would be a While loop that looped through and checked each condition but I wonder what impact that would have on the system. This would be especially true because I have other scenes I would like to do something similar to this with other scenes so more than one could be running simultaneously.
Also, is there a way to have a job constantly running on the system that could act as a clean up process? For instance, if someone accidently unlocked the Schlage lock I have I’d love to have something see that it has been unlocked for at least X minutes and then relock it - which presumably would be longer than a period time someone might intentionally unlocks it to unload a carload of groceries without having to constantly punch a code with each trip. Likewise, if no motion sensed in the house for an hour to turn off a list of lights if they were left on (this could also be nice if the LUUP engine was restarted when a scene was in a delay/wait state.
